Old 01-21-2010, 10:18 PM
Olfart's Avatar
Olfart Olfart is offline
Olfart is on a distinguished road
Default Have I fixed everything yet???
2004 H2 Black
Purchased Used 36,000mi
November 2006
37,600 - New Battery
38,250 - Wiper Motor and Module - Warranty
45,700 - Broken Shifter Wire - Warranty
Replace Water Pump and Belt - Warranty
48,120 - Replace Power Steering Pump and
Pressure Valve. Pitman and Idler Arms
worn. 2 broken exhaust manifold bolts(pull
heads to extract bolts) - Warranty
New Tires and Front End Align
49,000 - Water Leak - driver side floor wet.
Siliconed Marker Lights and cleaned
Sunroof Drains.
49,850 - Hood support cables rusted through
49, 870 - Eng Temp gauge not working. Sent inst
cluster out to be rebuilt (eBay)
2004 Black H2
Old 01-21-2010, 11:57 PM
CBR_Raven's Avatar
CBR_Raven CBR_Raven is offline
CBR_Raven is off the scale
Default Re: Have I fixed everything yet???
Originally Posted by Olfart
2004 H2 Black
November 2006
Sunroof Drains.
I think you have a lot of things covered already but I really wouldn't be concerned about EVERYTHING being fixed yet...the more you drive/use the vehicle, the more things will wear out or break. You have to expect to repair and replace things over the life of the vehicle if you drive it enough. Overall, I think the H2 is a great vehicle with low maintenance and if you have an extended warranty then that's even better. My H2 is not a daily driver so I don't have to worry about repairs as much.
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
Old 01-22-2010, 04:03 PM
Olfart's Avatar
The reason I posted the repair list is because these items seem to be common problems with the H2 and it looks like I am pretty well caught up. If there are any other "common" problems I'd like to know about them so maybe I can correct them before I get stranded on the road someplace.
I LOVE this truck and after being a Chevy Suburban man most of my life this H2 will be the last vehicle I will ever purchase.
2004 Black H2
Old 01-22-2010, 04:32 PM
splne1's Avatar
splne1 splne1 is offline
When you did the pitman and idler arms did you get the cognito brace for it??? Otherwise you will be doing it again. Just did my tie rods and pitman/idler arm myself. Waiting on my brace kit.
Old 01-22-2010, 08:10 PM
Olfart's Avatar
It was done under warranty...so I'm not sure about the brace. They didn't give me an itemized repair bill for any of their warranty repairs...just told me what they did. But the mechanics ( a GM Chevy dealer where I bought it...not a Hummer dealer) seemed to know what they were doing and actually replaced a few things that I didn't even know were going bad...such as the water pump, the broken manifold bolts and a bunch of fasteners that were missing or loose in various places.
2004 Black H2
Old 01-22-2010, 09:03 PM
splne1's Avatar
Yeah with more and more dealerships closing the chevy dealers have been doing most of the maintenance on H2's. Sounds like you were taken care of pretty good. The brace I am talking about just prevents faster wearing of the pitman/idler arms.
Old 02-04-2010, 10:29 AM
pohlease pohlease is offline
pohlease is on a distinguished road
I am having my pitman and idler arms done tomorrow. Also going to have them take out my airbag suspension and replace it with coils. My truck is a 2003 with 75 thousand miles. I am about ready to trade it in.
Now my unlock button doesn't work on my key fob.
Old 02-04-2010, 02:51 PM
Olfart's Avatar
Key fob should be easy and dealer will charge an arm and a leg for a new one. The conductive coating is probably worn off...it was on mine. Carefully pop it open and on the back of the rubber pad you will see dark areas which make contact with the circuit board. I got a small tube of powdered graphite and coated the contact areas on the pad. Don't overdo it....just a thin coating. You can also rub the side of a pencil lead on there, but it won't last as long.
This also works great on older TV remotes that have "dead" buttons
2004 Black H2
