Old 01-29-2010, 06:07 PM
bchas92097 bchas92097 is offline
bchas92097 is on a distinguished road
Default Dvd problems
I just bought a 2005 H2 Sut with the dvd mounted in the center console. It was working fine and now there is no power on the dvd player but the screens in the headrest work fine. I have check all fuses and they are fine. I was wondering if anyone else has had this problem. My kids might have done something but I dont know. Hope for and easy solution.
Old 01-30-2010, 03:39 AM
Viet Nam Vette's Avatar
Default Re: Dvd problems
If It is an after market unit the below will not apply If your misssing power to the unit then you'll have to trace backwards to the connection point and or fuse... DVD'S and CD Players do not like the cold temps. Thety develope "Tracking erro's which can cause the unit to not boot. If you have no power anywhere the a hunting you'll have to go
Cold is the enemy of electronics esspecially when it comes to DVD drives... I know My manual from the 09 says.. "Do not operate the DVD player untill the cabin temp is warm.
Not saying this is the problem ... but there could be an auto over ride in the sysyem untill it is warm enough to operate safely. If you live in a warm Climate then for get the above.
DVD AND CD drives are the worst.. I've worked on them for many a years professionally. To me they are the scrurge of the earth. To many moving parts and adjustments.
If it isn't a fuse ... try another disc in the sysyem.. If it won't boot but all else on your unit works then the problem is with the DVD Palayer unit.
Just My $.02 worth
Old 01-31-2010, 06:17 PM
Thanks but I have tried all that and I cant try another disc because I cant get the old one out with no power I have check all fuse and they are good. I live in South Carolina so it is fairly warm most of the time. Thanks I will keep looking.
