02-07-2010, 03:56 AM
New Tires and Leveling !!!!
Ok, Got my new 35's put on last Thursday (They look Awesome) after doing the torsion bar adjustment. Just got my new extended Bump Stops by Trail Duty and put them on. (Only took about 10min to do this). Going Monday to have the front alignment done.
Unless the alignment helps some, the new tires rub the sway bars a bit on full crank. I have read this is common and will not hurt anything. As for the shocks, I am still using the stock ones and not sure If I am going to upgrade as I have read that the Adventure shocks are a heavier duty shock versus the Base model ones.
The tire dealer like the look and was asking me if the 35" tires could be put on all H3's and said I was not sure as I had the Adventure Package with come with a beefier suspension.
I will be posting pics soon.
2006 Yellow H3 Adventure Package with 35" Firestone Destination MT Tires, Torsion Bar Adjustment, Trail Duty Extended Bump Stops, Chrome Trim Package, XM radio, 6 Disc Monsoon Stereo, Marker Lights, Brush Guard, Chrome Nerf Bars.
www.centexhummerclub.com
02-08-2010, 02:44 AM
Re: New Tires and Leveling !!!!
Congrats on the upgrades! Can't wait to see some pics!!
02-08-2010, 11:16 AM
Those 35's will rub on full turn. Once the alignment is done any changes will require realignments.
With the good turning radius of the H3 you really dont need to go full tilt often on the steering. When you hear it rub back off the turn slightly.
