Old 02-20-2010, 11:35 PM
tsdrummerboy's Avatar
tsdrummerboy tsdrummerboy is offline
tsdrummerboy is on a distinguished road
Default showing a DTC P0446
my 2003 is showing a DTC P0446.What is this and how do I fix it?
Old 02-20-2010, 11:48 PM
Easy Ed Easy Ed is offline
Default Re: showing a DTC P0446
Just get gas ? Might check that gas cap is tight.
Condition for setting the DTC
The fuel tank pressure sensor is less than -10 inches H2O
The condition is present for as long as 30 seconds.
Said it may take three times of starting the truck for it to go away after the cap is tightened.
Ed
Old 02-21-2010, 03:49 AM
Xotik H3 Xotik H3 is offline
Xotik H3 is on a distinguished road
Gotta love a good EVAP code. Autozone or Advanced Auto will reset it for you. May need to replace your gas cap, or take off and put it back on again.
Old 02-21-2010, 04:10 AM
thefinestimage's Avatar
thefinestimage thefinestimage is offline
thefinestimage is on a distinguished road
I had the same code, 4 times in the last 2 months. Had the dealer replace a few parts. I will PM you the parts they replaced. The last one to get replaced was the evap canister. It was coverd in mud. I know a sensor near the gas tank too. Again, too much mud. I will check my paperwork in the morning. If you reset it, I doubt the problem will go away.....lol. Better to fix it right IMO. Been a week, and so far so good. Seems like every 700 miles or so it would kick on.
07 H2 Lux, Volant CAI w/MAF and Hypertech PP III.
Old 02-22-2010, 10:16 PM
Bump, get it figured out ?
Old 02-23-2010, 12:05 AM
pdsq99f4 pdsq99f4 is offline
If there is a lot of snow where you are from, the vent solenoid could also be clogged with snow under the driver's rocker panel.
Old 03-22-2010, 03:19 PM
autotech2 autotech2 is offline
autotech2 is on a distinguished road
A lose or defective fuel cap is a more common cause of trouble code P0446, but if that's not it further testing of the evap system is required.
"An intermittent condition could be caused by a damaged evaporative emission (EVAP) vent housing, a temporary blockage at the EVAP vent solenoid inlet, or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem."
Ask Car or Truck Questions
Old 03-22-2010, 07:07 PM
Hummeron37s's Avatar
Hummeron37s Hummeron37s is offline
Hummeron37s is on a distinguished road
I replaced my gas cap when mine popped a 446 about 4 months ago, and so far so good
Rancho 4" lift-Rancho Dual Shock-MC2 Rims-Mud Grapplers-Gobi roof rack-Piaa Offroad light-Piaa FU lights-10"TV-Brushguard-Gobi ladder-Taillight guards-Hi-Lift Jack-PC Swaybars-Custom stereo-Blacked out taillamps, blinkers, marker lights and Roof marker lights-Purple Cranium Spider-License plate mod-Magnaflow Hi-Flow Cats & Cat Back Exhaust-DRL Mod-Cb w/Dual Whips
