Old 04-01-2010, 12:38 AM
kalantar kalantar is offline
kalantar is off the scale
Default anyone install a timbren kit on their h2?
I was told this is a good solution for pulling heavy loads and reducing rear end sagging, where as airbags have a 1000 lb capacity this has a 8600 lb capacity. Basically you removed the factory bump stump (which gives 4-6 inches of play) and replace with the timbren kit which only gives 1/2 inch of play. My main concern is that it will give a rough ride but the maufacturer says it wont be effected at all.
http://www.truckspring.com/timbren_285.html
Any thoughts?
Old 04-01-2010, 02:02 AM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Default Re: anyone install a timbren kit on their h2?
Yes, on a 1/2 ton truck several years ago. When empty they will beat the crap out of you. Work pretty well when loaded. I certainly would not put them on my H2. Try to find an air lift system. Much better solution.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 04-01-2010, 04:37 PM
HumminNBoatin''s Avatar
Do you have the Factory Air Ride suspension?
There is a similar system out there that allows you to put air bags inside of coil springs that guys have had allot of luck with. U just inflate the air bags via shraider valve when hauling a heavy load. Tomp is very familiar with this set up.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 04-01-2010, 05:12 PM
Old 04-01-2010, 08:19 PM
I have the regular suspension, is there a link?
Old 04-02-2010, 01:27 AM
Try sdtrucksprings.com They used to have a really cool set of air bags for the H2
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 04-03-2010, 10:46 PM
Astroboy Astroboy is offline
Astroboy is on a distinguished road
"Air Lift 1000"
http://shop.airliftcompany.cust.shop...00_Coil_Spring
I have these installed augmenting my coil springs.
I just inflate them with a bicycle-pump when I need to tow a heavy trailer.
Old 05-10-2010, 05:31 PM
Bimmer9938's Avatar
I have used Timbrens on vehicles, I don't think people know what you are talking about. They do not affect the ride at all with no load. They are basically a giant bump stop.
