Old 04-09-2010, 05:48 PM
numberoneolddiver numberoneolddiver is offline
numberoneolddiver is on a distinguished road
Default rear tire carried
I am interested in getting a rear tire carrier for my 2005 hummer h2,I looked at the units selling on e bay wondering if they are worth the money or try to find a used one.ny thoughts would be appreciated
Old 04-10-2010, 01:33 AM
bbtcorp bbtcorp is offline
bbtcorp is on a distinguished road
Default Re: rear tire carried
have one where are you located?
Old 04-10-2010, 06:51 PM
Default Re: rear tire carrier
no have not found one around my area
Old 04-11-2010, 08:14 AM
AK47's Avatar
AK47 AK47 is offline
AK47 is on a distinguished road
HI there I fitted one ,however I made sure I got one with three 3 mounting bolts on the hinge side there is early models of the tire carrier that has only two 2 bolts this has problems so if your buying one buy the one that has 3 mounting bolts ,it will mean that you will have to drill a extra hole for the third fixing also you will need to drill a whole into the rear bumper for the rear plate light ,that you will drill just to the right of the letter R where it says HUMMER make sure you get all the cables etc ,,good luck ,,oh I do believe the the tire mounts after 2007 had three bolt hinge fixings I could be wrong
Grant Ryeback
www.euroco-corp.com
http://www.hummertruckworld.com/EUROCO/
00423663114587
Old 04-11-2010, 02:39 PM
Devis1957's Avatar
Devis1957 Devis1957 is offline
Devis1957 is on a distinguished road
Don't know when they started with 3 bolts, but my ride is a 2006 and has the 3 bolt mount.......................
Pewter 2006 Luxury Edition
