Old 06-08-2010, 06:47 PM
trofeo16 trofeo16 is offline
trofeo16 is on a distinguished road
Default Single Stage Air Compressor to Dual Stage
I have a '03 H2. The single stage air compressor just called it quits so I ordered a new dual stage compressor. Spoke to the dealer and they stated that I need 2 new air lines (25903601 $69.47 & 15925802 $92.66) in order to make this work. DOes anyone know if these lines are in addition the lines I already have or if they replace ones that I no longer need to use? Any Help would be great.
Old 06-08-2010, 06:54 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Single Stage Air Compressor to Dual Stage
One replaces the air intake line with the filter. The other replaces the left airbag feed line if i remembr correctly
1998 Chev Z71
2007 Chev Trailblazer SS
Old 06-08-2010, 07:15 PM
Hellz Hellz is offline
can you post more info about this??
while my air ride is working just fine right now ( knock on wood)
i want to be someone informed of a good aftermarket replacement if/when it decides to quit.
Old 06-09-2010, 02:56 AM
Stupid Question, but is it worth spending the money on the 2 new air lines or is there simply a way that I can reroute the two existing lines to make them work with the two stage?
Old 06-09-2010, 03:45 AM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
Save money and replace it yourself
http://www.amazon.com/HUMMER-COMPLETE-AIR-SUSPENSION-COMPRESSOR/dp/B003P5BP9W/ref=sr_1_1?ie=UTF8&s=automotive&qid=1276051210&sr= 8-1
Old 06-09-2010, 03:51 PM
Thanks Mbdougl, thats exactly the company I just ordered the new compressor from. They originally sent me the old single stage even though the picture shows the 2 stage. They are correcting the error and should have the new one soon. Just trying to plan in advance to see if I need anything else before install, airlines etc. Also I wonder if its plug and play or will I need to take it to the dealer for a module reprogram and ride height reprogram?
Old 06-11-2010, 12:02 AM
HUMTECH's Avatar
You will need to have the trim height learned which requires a tech 2. The stage 2 modules are non programmable, if you try to program them it will kill the module.
1998 Chev Z71
Old 06-14-2010, 02:16 PM
pdsq99f4 pdsq99f4 is offline
The only line you really need is the inlet line. It has two inlets instead of one on the old system since it has two compressors. You just remove the old inlet
line and put the new one in it's place.
