06-17-2010, 05:10 AM
H2 160K Overhaul
Long story short our 03 H2 lately started to show sings of fatigue, finally last weekend following a friend in blue down GS Parkway at unsafe speeds to say the least we melted the selector fork in the TC. 4 locked is not fun on the black top. Since there is nothing nearly as original looking on the market as an Hummer SUV time to give some love after our H2 has given so much to us.
I did this to many times with my LR not to believe it's not going to snowball on us.
Short list:
-Transfer case rebuild
-Drive shafts rebuild
-Front diff re-seal
-CV joints
-Tie rod ends
-Driver front drive hub
-Repack rear wheel bearings
-Transmission chip
-Conserve under carriage
-Ignition coils
-Injectors
-HVAC control head
-Trace horn problem
-Assortment of upholstery problems
-Update the stereo
The truck is up and dis-assembly has begun and it's a mess under there!!!
Dealer quote "anything between 2.5k and 6k" can you say Ballpark figure LOL!!!
Missing the times when things where made to last.
06-18-2010, 08:56 PM
Re: H2 160K Overhaul
Looks like you got a good bit of work to be doing. And why would you drive on dry pavement in 4hi lock???
I have done it in emergency situations like once i broke a 1/2 shaft and did not have a spare. I had to drive it home for 55 miles.
06-22-2010, 03:24 AM
TC locked it's self, no selector fork, can't unlock.
Little progress today, TC out and drive shafts.
That's where those vibes where from, balance weights missing.
Water contamination.
Wasn't supposed to unbolt the adapter
06-22-2010, 09:48 PM
I assume your doing all this work yourself ?
2006 H2 SUT Fusion Orange LE
06-22-2010, 10:03 PM
Did my hubcap oil pan give me away?  Lol, yes it's happening in my garage.
07-05-2010, 11:03 PM
More progress today...
Man this bolts are on there!
Driver side needed some persuasion to come off.
Both sides are gone. Any one need a trail spare?
Got to keep things labeled.
07-05-2010, 11:19 PM
Kudos to you. I wish I had the know how to do that kind of work myself. I'm sure you'll save a ton of money, but you'll endure the frustration.
07-05-2010, 11:35 PM
Anybody can do it Haynes RM got step by step. And so far I used like only three different sockets. This one haven't been that bad so far, actually nothing compering to my other one.
Oooooooooo that's right I'm the enemy! LOL!!
07-05-2010, 11:39 PM
Come to think about it, why all the bolts so far on this truck are metric? Feels like I'm working on my Rover.
07-06-2010, 01:13 AM
Diff is out
Cross member rusted to ****!
Got to research upgrading to a Elocker.
07-06-2010, 01:52 AM
What is that?
07-06-2010, 03:31 AM
it looks like.....
you will need a bigger socket!
not sure if it is metric tho..
07-06-2010, 04:10 PM
I'd say this thread automatically qualifies jarek m far beyond the misnomer, "Hummer Novice."
2005 H2 Desert Sand Lux with partial adventure package
Show me a H2 owner with low profile street tires and I will show you a guy who thinks the coolest way to shoot a Glock is cocked sideways.
07-06-2010, 06:42 PM
Thanks VegasGuy.
07-06-2010, 06:44 PM
Just made this a family activity. Putting wife to work.
07-06-2010, 07:51 PM
Parts washer was the best money I ever spend.
Little sand blasting and ready for paint
That cleaned up nicely.
07-06-2010, 08:43 PM
I'm at 123K and just replaced original air bags on the rear suspension. Water pump is just starting to weep a little bit. I need to start putting together a to-do list.
07-06-2010, 08:50 PM
07-06-2010, 08:55 PM
Our rear air was a $1K three visits at the dealer NIGHTMARE!!!!! But I'm glad we kept it.
07-06-2010, 09:02 PM
now, im no professional mechanic, but i think the spring thingy was the cause of your problems... everything else looks good!
