10-25-2008, 07:53 PM
H2 Roof Marker Lights Question
Does anyone know which fuse(s) is used for the roof marker lights on the H2 (2005)? Or how the wiring for these is ran? I would assume above the headliner...but I'm looking for more specifics since I may have to access it to splice in a switch if the fuse is shared with other accessories.
I'd like to get those bad boys on a switch so they can be turned off/on...it's difficult to 'roll incognito' when you light up the neighborhood with red and orange Christmas lights. Don't get me wrong, they are badass...but sometimes I need to go 'low key.'
Thanks in advance.
10-25-2008, 11:17 PM
Re: H2 Roof Marker Lights Question
Originally Posted by guruerror
'roll incognito'
'roll incognito' translation: Scopeing out a neighborhood
10-26-2008, 12:03 PM
08-03-2010, 10:33 PM
I wanted to take a moment to thank you for the AllData diagram.
I finally got around to this project this weekend (almost 2 years later...ha) and was boosted when I discovered that the roof marker lights are all controlled by the INT PARK fuse in the engine compartment fuse box.
I used a $8.00 Bussmann fuse tap to construct a 'switched fuse' and put the switch in the dash near the headlight controls. Now those bad boys can be turned on/off whenever I want.
Thanks again.
CNTRY
DTOM
08-03-2010, 11:00 PM
just remember that the marker lights are required by law in some states due to the width of the beast. Weren't just put there for good looks
2004 Black H2
08-03-2010, 11:45 PM
It's actually a Federal regulation...(shrug)
CNTRY
DTOM
08-04-2010, 06:24 AM
I put smoked ones up there that came with their own bulbs. The bulbs looked like poo. The orange ones looked yellowish, and the red ones looked pink. Eventually, I just took out the bulbs. BTW, this was also the dealer's suggestion.
08-05-2010, 07:37 PM
so what bulbs did you put in there to replace the ones you took out???
or... didnt you...
i thoguht about getting the smoked lights. they are faily cheap on the bay. can pick them up for about $50.
did you ever find bulbs that made them look nice?
08-05-2010, 07:56 PM
Careful, I went el cheapo on the ebay ones and they melted with the bulb temps. I eventually paid for the smoked Recon set with a set of LED's. You get what you pay for nevers sounded so loud that day to me.
08-06-2010, 12:46 AM
I checked out the Recon's you mentioned. They look good. One question though, when replacing the lights do they just unplug all together or do you have to splice in the new ones?
Also for the OP> For rolling incognito"aka rolling dirty" I know on mine I can just click the light switch to the left and it turns off all lights.
08-06-2010, 01:57 AM
[quote=The_Yeti]I checked out the Recon's you mentioned. They look good. One question though, when replacing the lights do they just unplug all together or do you have to splice in the new ones?
The lights with The Recon Smoked Running lights are bulbs and they plug and play. The smoked lenses are the covers for the bulbs.
BTW grab a good tube of caulk to seal them up when done.
~Richard
08-06-2010, 02:20 AM
Not really the Recon lights come with a thick gasket like material under the light assembly no need for sealant. The cheaper lights didn't have this addition. The Led's I ordered are also from recon basic blug and play. Just like changing a headlight bulb.
11-08-2011, 03:47 PM
Just curious...are you still running with no cab marker lights? Have you gotten any negative attention from law enforcement?
It's been over a year now for me and no problems what so ever.
CNTRY
DTOM
