08-04-2010, 01:23 AM
engine light p0128 ?
My engine light came on .
On star said coolant problem ?
I checked with OB11 and reset.
Lights out now and didnt go back on.
What would cause that ?
08-04-2010, 08:41 PM
Re: engine light p0128 ?
A few short 12 mile trips and had it running parked for 30 minutes and no light
08-13-2010, 11:27 PM
Lights back on Im going to replace the thermostat .
Does anyone know the factory degree,s ? I searched and ther was mention of a 190 but not sure.
Any tricks replacing it ?
I assume its at the motor end of the front hose under the sensor there unless its hidden somewhere else ?
thanks
08-14-2010, 03:28 AM
Can't say for sure where it is, but usually with GM it is right under the water neck in the front. Also, 190 or 180 will be fine. Cooler is better for performance and economy, but either is fine for every day driving.
08-15-2010, 12:49 AM
Easy enough to install.
Its on the drivers side where the lower hose meets the engine ? Thermostat housing is straight the top one pass side is curved.
You have to remove skidplates and get to it from the bottom.
To get to the bolts you go through the wheel well.
for the upper bolt you have to jack the crossmember up a bit to raise the body.
I had a problem releasing the factory clamp,it was a bitch to do the one on the radiator so I replaced the thermostat housing side with a standard clamp.
Drained the radiator and put in 50/50 distilled water and anti freeze .
