Old 06-24-2010, 01:43 PM
HummerMann's Avatar
Default Transmission Temperature
I've noticed that driving in the 98F temperatures we've been having my transmission has been running at about 190. How does your transmission temperature run in hot weather?
Hummer, like nothing else
Old 06-24-2010, 02:10 PM
kchummer's Avatar
kchummer kchummer is offline
kchummer is on a distinguished road
Default Re: Transmission Temperature
In 100 degree temps mine runs around 175-190 range.....when it's that warm out it's gonna run about same temp as engine temp, which is usually around 200....if it gets higher I'd be concerned
Old 06-26-2010, 12:44 AM
VegasGuy's Avatar
VegasGuy VegasGuy is offline
VegasGuy is on a distinguished road
It was 103 in Vegas today. My transmission temp was about 190 also.
2005 H2 Desert Sand Lux with partial adventure package
Show me a H2 owner with low profile street tires and I will show you a guy who thinks the coolest way to shoot a Glock is cocked sideways.
Old 06-26-2010, 08:05 PM
tcalz06 tcalz06 is offline
tcalz06 is on a distinguished road
I installed the larger cooler mentioned on this site right after I purchased my 05.
In AZ with temps at 112 my tranny temp barely reads 150.
The cooler seems to work great. I've had it on for about 8000 miles so far
Old 06-28-2010, 04:38 PM
jmanley jmanley is offline
jmanley is on a distinguished road
So I've asked this question a few times. I was in the mountains in February, and it was -20F and the tranny, while pulling a trailer with 4 mountain snowmobiles on it (500# each - probably 1.5 tons total weight with trailer) and I was running trans temps as hot as 225-230F. Much too hot in my opinion, but when I talked to the dealer, they *claim* that this is normal and that it could go as high as 250F.
In my racing experience, anything under 200F is good, anything over 210F is bad, so it concerns me when it hits 225F and I can *smell* it!
Jay
Old 06-28-2010, 04:39 PM
What cooler did you buy, where did you put it, and how did you route the lines? Did you have a factory cooler as well?
Old 06-28-2010, 05:09 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Most everyone installs the Tru-Cool Tranny Cooler. I did it and like mentioned run 150ish. Last week I pulled an empty 24 ft Haulmark Trailer about 3500 LBS and ran about 190.
There is tons of info on this forum about it.
IMO this is 1 of the best MODs for the money you can do.
Here's the link to the search for "Tru-Cool"
http://www.elcovaforums.com/forums/s...earchid=264624
Old 06-28-2010, 06:15 PM
VegasGuy's Avatar
http://www.elcovaforums.com/forums/s...earchid=264613
FYI: No matches.
Old 06-28-2010, 07:23 PM
NJ H2's Avatar
Originally Posted by VegasGuy
FYI: No matches.
Funny ... I checked it after I put the link in. Anyway I edited it and put the link in again. It works now but if not just search "Tru-Cool"
Old 06-28-2010, 07:39 PM
H2illBilly's Avatar
H2illBilly H2illBilly is offline
H2illBilly is on a distinguished road
The Tru Cool tranny cooler is worth every penny. I installed it about 6 months ago and have never gone over 150 deg. If your not worried about the temp at least bypass the radiator. It's a tight fit but worth the headache.
Old 06-29-2010, 02:38 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
I am very interested in doing this myself. Could someone list all of the part # needed to do a very proffesional job. I would like all fittings to fitting where possible. Has anybody done a write up yet? If not I think I will do one, with photos.
Old 07-16-2010, 04:26 AM
Yep, Tha'ts what I used and used the write up on here for the install.
I just completed my second 3200 mile road trip with it from AZ to Illinois
works great at 116 degree outside temps running 80 up some big ass Hills through northern AZ
Old 07-30-2010, 10:32 AM
SmokeyJoe's Avatar
No Photos sorry,
I installed the cooler like this.
I removed the factory cooler the front of radiator. Drilled out the rivets from the bracket so I could put them back on later.
On the passenger side of the radiator is where the stock lines are for the internal cooler, remove lines and install fittings and place a hose between them to bypass creating a U shape.
You will have to cut the bottom line going back into the transmission, put a piece of hose on it and run it to the cooler.
The output line cut the line and run the hose to the other side of the cooler.
Any cut lines I used a pipe cutter then double flanged them to make a mushroom.
The only problem I have run into is the positioning of this huge cooler. Right now its hard to close the hood because it is hitting the 2 bolts for the bottom brackets. I will have to reposition this later.
So how does it work, maybe to good. I drove to work today (55F) and the temp never broke 130F, and most of the time on the highway (80MPH) it stayed around 110F. I am not sure if this is ideal or not, as I just went by the recommedations here. So if anybody knows about this please let me know?????
While doing this I changed the filter and fluid. After I changed the filter, I took the upper radiator transmission line off and put about 5" of rubber hose on it. Then clamped it to a big bucket. I had my wife start the H2 up, and as it pumped the fluid out I poured new fluid in until it ran out cherry red.
So while I was at it I decided to change all of the fluids- radiator, diffs & trans case.
Old 08-20-2010, 12:16 PM
giant h2's Avatar
giant h2 giant h2 is offline
giant h2 is on a distinguished road
Anyone try a fan on the factory cooler??? I have been told that a larger cooler will affect the AC.
Old 08-20-2010, 01:50 PM
NJ H2's Avatar
I have the Tru-Cool and my AC works the same
Old 08-20-2010, 02:11 PM
SmokeyJoe's Avatar
Just an update to my recent install.
I just came back from vacation in northern Italy. The temps were around 90 with very steep inclines. The temp got up to about 170 at the very highest, but normally hung around 150. It was slightly cooler in the Swiss Alp but the mountains were quite steep, the temp never broke 170 there either.
So the temps do start to rise it just takes a little while before they get there.
Seems now for the most part they hang around 150 after driving for 30 minutes or so, otherwise around 130.
