08-25-2010, 03:12 AM
Re: H2 160K Overhaul
Test drive didn't go that good.
Missing the times when things where made to last.
08-25-2010, 03:08 PM
Leaking cooler? Did you have it apart, or is it a new problem?
Mirror caps - black bedliner
08-25-2010, 03:23 PM
I love threads like this. Keep the pics coming. Regarding some of those surface rust issues. Do you live in a very humid part of the states??.Ive never seen surface rust like that on interior componants.
08-26-2010, 02:11 AM
Dude...I'm all about DIY, but, man you are out of control. This is an awesome thread. You're the MAN!
CNTRY
DTOM
08-26-2010, 06:18 PM
All and all, every thing works just fine if not better. The PS cooler leek is a new thing but a easy fix, got a new cooler with lines on eBay for $40  . The truck also is pulling a P0135 even thou all O2 sensors are new-ish, I'll give it couple of days maybe it clears it self. I still have to do the injectors only 7 came in still waiting for one.
On to the interior!!!!
08-26-2010, 06:33 PM
I think NJ is the most humid of them all and we just moved away from the coast line.
08-26-2010, 10:13 PM
08-26-2010, 10:16 PM
Can you post a pic of what the back of one of the door panels looks like. I'm getting ready to pull mine off to have 'em Line-Xed and I was wondering how the 'leather' sections (top and arm rest) were attached to the plastic...easily removable? Not removable?
Thanks in advance!
CNTRY
DTOM
08-26-2010, 10:36 PM
Thanks in advance!
No, there "heat riveted" together that's why I'm keeping them in one piece for paint.
08-27-2010, 02:48 PM
Thanks for the quick reply...I think I may pop a back one off and try to work with those welds. I really want the panels to be Line-Xed. If I can get the leather bits, speaker grill, and the handle off I'm good...I'll have the remainder sprayed as is.
I feel confident that I can release those welds without permanently damaging the panel...just need to soften them up with a soldering iron. I'm gonna practice on the welds for the door panel pocket. My goal is to permanently remove the pockets from the rear doors anyway.
I may start on this project this weekend...I'll open a new thread once I do so I don't keep interrupting this one.
Thanks again...and GREAT work.
CNTRY
DTOM
08-27-2010, 05:59 PM
I wonder if you could dremel out the welds without going through to the otside, and then reattach the panels with something like velcro strips, since they look like they have lots of overlap.
Or, what about using allen head bolts that match the ones for the dash? That might look sort of cool. The bolts would be in the plastic part, and with the LineX you probably wouldn't need washers on the outside. If you did you could use black ones.
08-27-2010, 08:11 PM
MOVED THIS TO A NEW THREAD: Door Panel Disassembly (2003-2007)
CNTRY
DTOM
08-27-2010, 08:50 PM
What colour are your rear pockets??. Mine are missing.
08-27-2010, 08:55 PM
You have done a nice paint job on those interior parts....
08-27-2010, 09:27 PM
I MOVE THIS TOPIC SO WE DON'T HIJACK THIS THREAD: http://www.elcovaforums.com/forums/s...ad.php?t=40144
CNTRY
DTOM
08-28-2010, 08:27 PM
08-28-2010, 08:38 PM
Its like Christmas time today, more parts...
08-28-2010, 09:34 PM
Very nice! The steering wheel buttons look easy enough to change. Good to know.
08-29-2010, 02:58 AM
Steering wheel buttons replacement.
Your the man if you were able to replace those without disassembling the new switches. I've replaced all four buttons...I had to take apart each one in order to get them installed. I just didn't have enough slack in the cable to install as your illustrations demonstrate.
Keeping all the lights working in this truck is definitely a challenge.
CNTRY
DTOM
08-29-2010, 05:41 AM
Hey Jarek I sent you a message about removing your front diff.
