Old 09-23-2010, 05:57 PM
chris4851 chris4851 is offline
chris4851 is on a distinguished road
Default Squeaky suspension?
Has anyone had any issues with their suspension squeaking? I have a 2006 H2 Luxury and this happens typically at low speeds, however it could be because I can actually here it at these speeds. For example when I pull into my driveway the car will sway from the right turn I have to take and I constantly hear the suspension squeak. Could I need new suspension? The suspension when I go over bumps feels fine and the ride also feels fine. Any thoughts?
Old 09-23-2010, 06:51 PM
kchummer's Avatar
kchummer kchummer is offline
kchummer is on a distinguished road
Default Re: Squeaky suspension?
I think they all squeak do to the rough suspension the H2 has....I know mine does it and it's still like new w/ 30k on it and NEVER offroaded....LOL
Old 09-23-2010, 07:00 PM
dvl57's Avatar
dvl57 dvl57 is offline
dvl57 is on a distinguished road
Default Re: Body Mounts could be causing this
Chris,
take a look at this old post. Mine would squeek at low, slow speeds- I thought it was the suspension too. It turns out its the body mounts that need to be replaced.
http://www.elcovaforums.com/forums/s...ad.php?t=38283
I had it done at the dealership under warranty. Now, no more squeeking.
Hope this helps.
Don
2008 H2
Billy Boat Exhaust
Old 09-23-2010, 11:53 PM
Braveheart7's Avatar
Braveheart7 Braveheart7 is offline
Braveheart7 is off the scale
Mine squeeking its brains out..and then the occassional metal to metal clunk.... very low speeds like parking etc ..... when I changed the front wheel bearings ... for the HUM ....the noise is gone.
Old 09-24-2010, 12:56 AM
Scarsman's Avatar
Scarsman Scarsman is offline
I have a squeak too, that I am trying to figure out. It's in my left front and it does it when I am turning the wheel while it is under compression. Like on a trail when left front is on something so it is compressed. It is not while bouncing, like from bumps, it only does it when the wheel is being turned. I was thinking ball joint, and so I greased them, but they were not dry at all and it still does it.
Mirror caps - black bedliner
Old 09-24-2010, 01:44 AM
seventwozero's Avatar
seventwozero seventwozero is offline
seventwozero is on a distinguished road
I'll join the wagon and say I have a chirping sort of squeek coming from what I think is the driver rear area. I hear it mostly when shutting the door or going over railroad tracks, I've read that the shock towers sometimes do this, definatly not a clunking noise like some of you though.
2004 white H2 SUV lux
Old 09-24-2010, 03:25 PM
dvl57's Avatar
It's not suppose to squeak. My service advisor told me the body mounts fail..which causes your squeaking at low speeds. They need to be replaced. I thought it was the shocks.
Anyways, from what I remember, another member posted that there was a TSB on this.
ya'll should check out that post that I linked.
The squeaking wasn't that big of a deal, but it sure is embarrassing when you're driving through a neighborhood and you go over a speed bump...and the pedestrians look over to see what's all the racket.
Don
2008 H2
Billy Boat Exhaust
Old 09-24-2010, 09:28 PM
twr's Avatar
twr twr is offline
Hi It could also be the front axle mount their is a big steel washer between the mount and the axle and if that is dry it will make noise and it sounds like its coming from the rear, front all over it was driving me nuts. It would happen when stopping for a light or going forward and turning. It took me 1/2 hour to find it when the dealer couldn't. Hope this helps.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
