Old 09-25-2010, 02:41 PM
giant h2's Avatar
giant h2 giant h2 is offline
giant h2 is on a distinguished road
Default H2 Trans Oil Cooler
Has anyone tried to put an electric fan on their tran-oil cooler?
Old 09-25-2010, 05:03 PM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
Default Re: H2 Trans Oil Cooler
One of these: http://www.oregonperformancetransmis...de=NTP-K51828C
One of these: https://www.dieselsite.com/index.asp...ge=1/index.asp
One of these; http://www.bulkpart.com/Merchant2/me...roduct_Count=4
And my transmission temperature never goes above 150 even in 100 degree heat. The Transmission cooler lines no longer go thru the engine radiator.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 09-25-2010, 08:06 PM
giant h2's Avatar
What about your AC does the new radiator for the tran oil mount in front of condenser? If so does the AC blow as cold?
Old 09-26-2010, 03:51 PM
H2R's Avatar
H2R H2R is offline
Exclamation Re: H2 Trans Oil Cooler
AC AND ENGINE TEMP WORKS FINE NO ADDITIONAL COOLING NEEDED. The engine is also supercharged and it all works well. The only problem I had was with the plastic tank for the intercooler which cracked at the mounting point but all is well now. Just dont wait till your transmission overheats if you plan the mods.
2013 Sierra Denali
2012 Yukon Denali
Old 09-27-2010, 10:18 PM
The lines never went through the engine radiator.
Old 09-27-2010, 11:56 PM
edbrick edbrick is offline
edbrick is on a distinguished road
I thought the lines ran through the radiator also.
Old 09-28-2010, 12:19 AM
giant h2's Avatar
I believe that my lines run up from the trans on the passenger side to the radiator cycle thru a side mount then out to a trans cooler in front of the radiator?
Old 09-28-2010, 01:38 AM
hurricane hurricane is offline
hurricane is on a distinguished road
whats the " external thermal bypass " do ? and how's the Tru-Cool MAX transmission cooler ? is it the best ?
my country temp maximum 140F and minimum 35F in the winter ..
my transmission temp always be at 150 to 200 .. without pulling anything .. normal riding 150-175 but when i go fast it hit 200 and little more .. 2003 H2, i have an electric hummer 2009 fans, no clutch... ac is good engine temp is good too but only the transmission is getting hotter ..
2003 Pewter H2
- BFG's, Electric fans, Coil spring, Magnaflow Muffler, Xenon HID.
Old 10-01-2010, 01:01 AM
tcalz06 tcalz06 is offline
tcalz06 is on a distinguished road
My AC at idle around 110 degrees or higher doesn't work. I'm sure the ground temp off the freeway is 170 but I think the cooler did it.
The AC works great while moving but idling in traffic it sucks
Old 10-12-2010, 01:31 AM
H2illBilly's Avatar
H2illBilly H2illBilly is offline
H2illBilly is on a distinguished road
Ummm... After reading this thread I have to post just because I have installed the Tru-Cool cooler and would reccomend it to everyone. I'm in south FL. and have zero issues with this cooler. In 95deg heat, pulling a 25ft. boat, I have yet to go over 150deg on trans temp. Personally I don't feel an electric fan is necessary. Your tranny lines run from the trans to a "reservoir" tank on the passenger side of the radiator. This serves no purpose, buy the Tru-Cool and bypass the radiator... you'll be happy with it. Also if your having problems with your A/C after you install the cooler chances are it's A/C related, the cooler will not block the air flow in front of your condenser.
