Old 10-13-2010, 01:40 AM
Faustus100 Faustus100 is offline
Faustus100 is on a distinguished road
Default Engine rebuild
Just out of curiosity-what would it cost for a complete engine rebuild on a H2.
Not that I need one(thank God).I just have made up my mind to keep my H2 till Im dead and buried so I thought Id ask.
Old 10-13-2010, 02:13 AM
H200 H200 is offline
H200 is on a distinguished road
Default Re: Engine rebuild
Which engine and whats the year?
06 H2
05 H2
Ohio Hummer limos
Old 10-13-2010, 08:30 AM
the 6.0 the year is 03
Old 10-13-2010, 09:13 PM
Intercooled's Avatar
Intercooled is off the scale
curiouse my self. Plan on keeping this sucker for some time, ya never know.
2006 H2 SUT Fusion Orange LE
Old 10-13-2010, 10:26 PM
SqwkVFR SqwkVFR is offline
SqwkVFR is on a distinguished road
A competent shop should be able to rebuild for 3-5K depending on what needs to be replaced, and the ammount of machine work needed.
I, too, will be keeping my H2 for a long time, and when the drive line gets old and tired, I'm most likely putting in a LSX376 with a TVS2300, and a 4l80E. Lots more $$$ but Lots more power and fun. And bullet proof.
Old 10-14-2010, 02:02 AM
Xotik H3 Xotik H3 is offline
Xotik H3 is on a distinguished road
I would not rebuild the stock motor, replace it a create motor to the same specs. If you rebuild it and need to bore the cylinders which you may, you change the displacement of the engine - meaning the stock computer program will not operate the engine correctly. So if you rebuild the stock engine you will probably have to get a custom tune. If you go that route, might as well replace the cam for low end torque and economy, replace the heads with better flowing ones... get the tune. You will have better economy, more low end power, and a fresh engine.
New rings, bearings, gaskets, no machine work... do it yourself in 3 weekends - $1,500 including the tools you need to get it done. While you have it out, get a reman trans and rebuild the transfer case. You could do it all for $2,500.
