Old 10-21-2010, 02:04 AM
mack04 mack04 is offline
mack04 is on a distinguished road
Thumbs up Need some help with my H2
Ok I dont know if my rear air bags or bad or not. But it seems like if my hummer sits for about or week or longer the back end drops. This has only happed couple of times. I tried the soap and water on them but i dont see an air leak. Will the air bag go down on there own if it seats to long?
thanks
Old 10-21-2010, 02:18 AM
twr's Avatar
twr twr is offline
Default Re: Need some help with my H2
Hi they can leak many places you need to check all the lines and all the items up where the air compressor is. Also the bags may take awhile to show bubbles, is their alot of cracks in the rubber?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 10-21-2010, 02:26 AM
I did check all of the line i lets the soap and water on for about hour.
Old 10-21-2010, 02:32 AM
twr's Avatar
twr twr is offline
Hi if you have checked it and can't find anything and it only does it sometimes and after a week. It is going to be hard to find untill it gets worse. I think i would just keep a eye on it right now.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 10-21-2010, 02:37 AM
If it does get worse would you but air bags back on or do springs? And where could you get them at?
Old 10-21-2010, 04:06 AM
twr's Avatar
twr twr is offline
Hi the air ride can be very costly to repair even if you can fix it yourself. When most guys here have problem with the ride they put coils in because it usually problem after problem as the truck gets older. I think coils and the rubber isolator are $275 to $300 here is a link to one place but their is a bunch out there. http://www.airsuspension.com/Hummer-...t-p/-h2-r1.htm
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 10-21-2010, 11:25 AM
H2illBilly's Avatar
H2illBilly H2illBilly is offline
H2illBilly is on a distinguished road
Hey mack04, I dont have air bags and I'm glad I don't. But if it was me with the problem your having I would convert to coils and be done with it. It should be pretty easy to do and cost less than replacing bad bags. Good luck though.
Old 10-28-2010, 08:18 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
Convert to the coils, I did. It takes a little getting used to at first, but only because you won't feel like you are riding in a feminine Escalade. Besides that, not only will the airbags go bad, but eventually so will your compressor ($1000 - $1250 not including labor), so could the compressor switch ($250 or more not including labor) and so will the air suspension light goin nuts acrossed your dash if you ever decide to lift it. Just putting in my 2cents from my experience.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 10-29-2010, 02:42 AM
Thanks i will have to put the coil springs on
