11-02-2010, 08:31 PM
service 4WD
04 H2 69k and suddenly the service 4WD light comes on and the 4WD light on the dash flashes, but not everyday. ???? I'm trying to get an idea before the dealer soaks me
11-02-2010, 10:19 PM
Re: service 4WD
I had the same thing happen this summer. Put it into 4low and drive it around a little bit and 4 lo lock and do the same. It's from lack of use in low range.
1994 Chev Suburban Blown
11-03-2010, 01:44 AM
Re: service 4WD
I had the service 4WD come on and now I cannot shift into 4LO. I don;t have any codes popping up right now but will try it again when it comes back on. If you resolve this, shoot me some information if possible.
11-03-2010, 01:05 PM
Re: service 4WD
I've had this light once in both of my H2s. In the '03 it was solved as per the dealer suggestion of shifting from 4L to 4H 15 times - does something to the contacts in the transfer case. When my '06 got the light I tried the same thing and it didn't work and the dealer found my 4L switch had gone bad on the dashboard.
Hummer, like nothing else
11-10-2010, 02:49 AM
Re: service 4WD
I had exact same issue and ended up having the dealer fix it. Ended up being the switch as well. At first it was intermittent but then the light on my dash kept going out and and after trying all the suggestions, I took it in and they replaced the switch. I think it was ~$350
11-29-2010, 07:50 PM
Re: service 4WD
Thanks, That was it!
12-11-2010, 04:40 PM
Re: service 4WD
'05 with 84,606 miles...Service 4WD popped up yesterday. Goes into 4HI and 4LO fine.
Dropped it off at the dealer last night...will post back later today when I get the results.
CNTRY
DTOM
12-12-2010, 12:33 AM
Re: service 4WD
Dealer 'traced out 4 wheel drive circuit' and 'found internal open in 4 wheel drive mode switch'
$150.28 for new switch and I'll do the install tomorrow...should fix it all up.
CNTRY
DTOM
12-12-2010, 10:59 PM
Re: service 4WD
That fixed it right up...no more Service 4WD message.
CNTRY
DTOM
