Old 11-18-2010, 04:30 AM
bulldogscott72 bulldogscott72 is offline
bulldogscott72 is on a distinguished road
Unhappy H2 FUEL PRESSURE ISSUE?
I hope some of you have a point of attack on this! I have a 2003 H2 with 85000 miles on it. The problem is: when I first try to start it, it will only crank for about 3-5 Seconds before it starts. If I turn the key on & off 3 times without cranking it, it will start right away on the 3 turn & crank. I don't see any signs of a leak under the hood. Another weird thing it does, is if I park it nose first in my drive way that is on a Incline it will start on the first crank, but if I park it level then I have to turn the key on & off 3 times, while waiting for the orange fuel light to go off each time before it will start right up. This has happen ever since I bought it USED for a good price. No codes or anything come on, just bought a new fuel cap, & still the same thing. Don't have the cash to take it to a dealer, so any help would be greatly appreciated.
Old 11-18-2010, 02:29 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Default Re: H2 FUEL PRESSURE ISSUE?
How is it once its running, seem down on power at all? It sounds like it could be something as simple as a new fuel filter, if you have 85K and its never been replaced it could be what your problem is.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 11-19-2010, 08:07 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
sounds like the fuel pressure regulator is allowing the fuel prime to bleed off slowly which would be why you need to prime the system 3 times for it to start after sitting. also could be a leaky injector. Put a fuel pressure gauge on it and pressure system up with a few key cycles then watch the pressure, if it drops slowly pinch off the fuel return line. if it continues to drop, injector is leaking, if it stops dropping regulator is leaking
1998 Chev Z71
2007 Chev Trailblazer SS
Old 11-20-2010, 02:19 AM
MVR it runs perfect once it is started, Humtech what is the easiest way to put a Fuel pressure gauge on the system? I Appreciate all the help, thank you guys. I Would like to try and get this figured out this weekend.
Old 11-20-2010, 02:28 AM
Easy Ed Easy Ed is offline
On a 2003 where the yellow dot is at.
Attachment 53117
