Old 03-12-2011, 11:23 AM
dave2165 dave2165 is offline
dave2165 is on a distinguished road
Default PLEASE HELP!!!leak on passenger floor
PLEASE HELP!!! my passenger side rug is soaked but it has no smell like anitfreeze..i cant see where it is coming from and its not from rain help!
Old 03-12-2011, 09:26 PM
Intercooled's Avatar
Intercooled is off the scale
Default Re: PLEASE HELP!!!leak on passenger floor
Try a search. There are few threads here with your common problem. Those threads are pretty extensive with some good solutions.
Sounds like a marker lamp or sunroof drain leak.
2006 H2 SUT Fusion Orange LE
Old 03-12-2011, 11:46 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Check your hvac module drain hose at the bottom of the right side firewall in the engine compartment. If it is plugged condensation in the hvac module assembly has nowhere to go but on your floor
1998 Chev Z71
2007 Chev Trailblazer SS
Old 03-13-2011, 02:24 PM
I looked on the fire wall and the hose is gone the only thing there is an elbow so i put a plastic hose in it and blew a few times there didnt seem to be any resistance then i cut a 8 inch piece of hose and attached it so it would drain away...could it be that bc the hose was gone the water flowed out of the elbow and down the fire wall and back into the car?
Old 03-14-2011, 12:00 AM
HUMTECH's Avatar
Hard to say, if it was clear its not likely the cause. I would start looking under the dash area for signs of water staining anywhere. Pour water in the front sunroof drip tray and verify it flows through drain tubes that exit just in front of both front doors. Also check for water coming from roof marker lamps.
1998 Chev Z71
Old 03-21-2011, 11:24 PM
i dont have a sun roof on my truck do i still have a drain ? ..or can it be the marker lights?.. it seems as if the water is pooling some place
Old 03-22-2011, 12:33 AM
mightyepp's Avatar
mightyepp mightyepp is offline
mightyepp is on a distinguished road
Put silicon around the front marker lights. I had the same problem, and now it is fixed. Water was getting under the front middle three marker lights on top.
2003 Hummer H2
Old 03-22-2011, 08:47 PM
I will give it a try..thanks.
Old 03-25-2011, 11:55 PM
kmleong kmleong is offline
kmleong is on a distinguished road
Had the same problem. Went to the bodyshop 3 times. 1st time resealed the marker lights. 2nd time did a flood test (passenger door open) looking for water coming in from windshield,cowl,sunroof. 2 hrs nothing. Went home and found leak when I went out to dry floor. It was the large rubber grommet in between the hinges on the door frame. Water would fill up and dribble out the round hole on the inside of the door frame. RTV'd the grommet and no problem since. Hope this helps
2004 H2 Lux; Night vision, Helix Tower power 11, Volante CAI, Diablo Predator, Bluestar, 20" Weld Racing, 325/60 Terra Grapplers, Rancho 5000's + Steering Stabilizer, XTC Lightbar,Hella driving lights, Compustar Alarm + Remote start, 2 Elec. fans, Tru cool 4739, oem Rear camera,console vault
Old 03-28-2011, 04:09 AM
Also pull the covers off the two outside front marker lights. 1 Phillips screwhead hold them in place. Pull the rubber plug out, put rtv around the hole, than push them back into place. I had to do that to a couple of trucks. Solved the problem.
Old 03-28-2011, 07:43 AM
wingn69's Avatar
wingn69 wingn69 is offline
Check the rubber bushing around the wiring lum in the door jam. thats is one of the location I had water coming in from on mine RTV and its been dry for a year now. I had mine in the shop for over a week trying to find water leaks they remove and re-sealed
marker lights
sunroof
door wiring lume
and the real fun was the windshield had been put in wrong after a replacement from a rock cracking it and the installer reused the old seals and it was leaking.
