Old 07-18-2011, 03:56 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
Default Surging Between 45-50 MPH
Lately I've been getting an inconsistent surging in my RPM's when cruising between 45-50 MPH. I can visibly see the tach needle jump. It usually does this when I first take the truck out, and then basically goes away. Took it to the dealer and they did the injector cleaning, etc., but I'm still getting the problem. They suggested that it could be the transmission, but wanted to look at some cheaper fixes first.
Any ideas?
Thanks,
Charles
Old 07-19-2011, 03:30 AM
twenty2's Avatar
twenty2 twenty2 is offline
Default Re: Surging Between 45-50 MPH
Any ideas?
Thanks,
Charles
possible that its signs of your fuel pump going bad... anyone else want to chime in on this?
Old 07-19-2011, 08:02 AM
ben86's Avatar
ben86 ben86 is offline
ben86 is on a distinguished road
Mass Air Flow
www.hummertravel.com
Old 07-19-2011, 12:37 PM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
Throttle body dirty, Butterfly getting stuck open. Just a guess like the others.
Old 07-19-2011, 01:18 PM
charles06's Avatar
I appreciate the help everyone.
The problem we're having diagnosing it is that it's intermitent. I can't get it to happen when I'm at the dealer...of course. Like I stated earler, the dealer did the injector cleaning and all that crap. I'll ask if they scrubbed out the throttle body.
Old 07-22-2011, 02:41 AM
devilsfan's Avatar
Please post if you find a fix. Mine does this at idle - not every time, just every now and then. Usually after I run it for a bit, shut it off, then restart 30-60 mins later. It will surge until I give it gas, then it's fine. Can't duplicate it at the dealer either!
Stacy
