Old 08-10-2011, 02:55 PM
Scooter911 Scooter911 is offline
Scooter911 is on a distinguished road
Default 37x12.5x17 on stock rims
I know this has been asked, but the answers always left some doubt as to the setup so I'd like to get this clarified before I buy.
I have a 2003 H2 with original rims.
I'd like to install 37x12.5x17 BFG MT's.
Because I have to special order these tires in (PRE-paid), and then bring my rims in separately because no one is willing to install them on my truck due to perceived liability, I'd really like to make sure that I'm making an informed purchase.
I have the original 17" rims and no lift kit, etc... Will 37's fit on my truck? I've read some posts that stated some extra 'work' was required to get larger tires to fit.
Any input would be greatly appriciated.
My biggest fear would be to get these tires in and then discover that they don't fit.
My current plan was to purchase 1 tire and install it on my spare rim to test for fit. Worst case is that I would be stuck with only 1 tire if it didn't fit.
Kelly
Kelly
Old 08-10-2011, 03:47 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Re: 37x12.5x17 on stock rims
37's should fit just fine if you crank the keys a bit.
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
Old 08-10-2011, 03:52 PM
Thanks for the quick response!
Can you describe what 'crank the keys' means?
Kelly
Old 08-10-2011, 04:10 PM
Doing some research now... Seems fairly simple to adjust the torsion bars.
Kelly
Old 08-10-2011, 10:46 PM
Indy's Avatar
Indy Indy is offline
Stock keys adjust about an extra 0.5" to 1", depending on how they were set up from the factory. You could always get aftermarket keys if you want to go a bit higher. To adjust the keys, unload the front suspension and turn the bolts holding the keys up (about in the center of the car, where the torsion bars end). 37's should clear with minor rubbing on the frame and a-arms, but just very minor rubbing at full steering lock. Shouldn't cause much problems. There are also spacers available for the rear springs if you want to raise the back of the Hummer. If you want to mount the tires, bring them to a truck shop. That's where I had mine installed. They mainly do tires for big semi-trailers and other heavy machinery. They have big balancing machines and should be able to properly balance the tires. Good luck with your tires. Cheers, Indy.
Old 08-11-2011, 01:11 AM
Thanks. I feel much more confidant now after doing more research!
I'll place the order next week and then post the results.
Kelly
Old 08-12-2011, 09:04 PM
HumminNBoatin''s Avatar
You will not need to crank the keys with those specific tires. They will fit just fine. If you go with a wider tire then you will need to crank them.
Get Dyna Beads Search for them on google. put those in the tires and you will never have to balance the tires.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 08-13-2011, 01:00 AM
Searching now for Dyna Beads...
Old 08-13-2011, 04:54 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
I have the same tires on my '03...fit just fine. No crankin' or nuthin!
Old 12-14-2011, 03:59 PM
sanfoja's Avatar
sanfoja sanfoja is offline
sanfoja is on a distinguished road
Strange cause I have Goodyear MTR (Kevlar) 37x12.5x17 WITH aftermarker cranked keys (2" lift in front) and I still rub the swaybar at steering wheel lock. My bars are pretty shiny from getting rubbed by these big rubber erasers...
Love the look and performance though, so worth the trouble
Joe Sanford
Huntsville, AL
2003 H2 Lux/Adventure, Burgundy, 37x12.5 MTRs on Matte Black Wheels, Smoked Cab/Running Lights, 07 Mirrors, Jet Stage 1 Chip, Volant CF CAI, AirRaid Intake Tube, Bi-Xenon HID, DRL mod w/diode, 2006 TNR, Matte Black Linex on Grilles & Front/Rear Bumpers, Ram Offroad Brush Guard, Rancho 9000 Remote Adj shocks, Rancho 5000 Strg Stab, FFD Ultra Extreme Electric Fans, Moog Pitman/Idler w/Cognito Support Kit, Kryptonite Tie Rods
Old 12-14-2011, 04:54 PM
2010_5thgen's Avatar
2010_5thgen 2010_5thgen is offline
2010_5thgen is on a distinguished road
do those really work? never seen those before. is balancing still required? or recommended?
2012 Porsche Panamera 4
Old 02-28-2012, 09:45 PM
OldHiker OldHiker is offline
Looking for my third set of 37 for my truck. The only thing I had to do to get these to work was install them. NOTHING is required. No rubbing no nothing. Never tweaked the torsion bars. At least on my '04 that's been offroaded all over the country including the infamous Rubicon.
Old 02-29-2012, 12:21 PM
jsbihn jsbihn is offline
Moderator
Does anyone have any pictures of these tires mounted on the stock rims while mounted on the truck?
Old 02-29-2012, 06:24 PM
guruerror's Avatar
CNTRY
DTOM
Old 03-01-2012, 11:06 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
very informative thread. I'm still relatively new to the hummer world and have researched quite a bit but just assumed 35's were stock. I can't believe how much better the 37's make the truck look in the pics above-fills the gap!
My stockers rub a tiny bit on the sway bar but its nothing major-I've read that can happen. My first set of tires for this thing will definitely be 37's-as long as I can still fit the thing in the garage lol.
Thanks again for the info everyone!
Old 03-01-2012, 02:42 PM
Originally Posted by guruerror
are those chrome wheels i see? i thought chrome wont get you home?
Old 03-01-2012, 02:58 PM
guruerror's Avatar
LOL!
Yes, they WERE...and have since been DELETED.
CNTRY
DTOM
Old 03-01-2012, 08:17 PM
Lol. Got any pics of them on the truck?
Old 03-01-2012, 08:34 PM
guruerror's Avatar
What?! You don't believe me?
I even put little RSs on the ATV
CNTRY
DTOM
Old 03-01-2012, 09:12 PM
looks good. you need some for that trailer now.
