10-06-2011, 10:36 PM
Re: LIFTED HUMMERS THREAD!!
Here you go.
10-06-2011, 10:40 PM
He must not turn much.
CNTRY
DTOM
10-07-2011, 02:22 AM
Originally Posted by Bimmer9938
Here you go.
hahaha..you would!
Exactly what I was loooking for!
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
10-07-2011, 02:41 AM
Here you go.
WOW ....That is SWEET!
10-07-2011, 02:49 AM
Here's a lifted Hummer...
aka: Mini Me.
10-07-2011, 02:53 AM
HAHA that is cool. Did you build yours before ya found it?
10-07-2011, 02:54 AM
I found it after I built mine, but I had to paint it black to match Big Black.
10-08-2011, 03:16 AM
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
10-08-2011, 03:20 AM
In case of the asks: Treehugger, rockstar 20"s, Toyo 40"s, Amp steps, Gobi rack and ladders, stock swingarm, Putco Smoked LED rooflights, powdercoated stainless rear rock grills, chipped (Superchips), regeared 4.88's, Defenderworx fuel door, tons of custom inside; rest of the chrome soon to go.
Santa's list:
- Supercharger
- Black paint job
- Custom black leather interior
- Custom hiding spots for my James Bond stuff inside
- Coated from head to toe in offroad lights
10-08-2011, 03:38 AM
Of course! Broke a CV just last month too add. Forgot to mention that I pulled the air system and am rocking coils underneath with Bilsteins too because the air system couldn't hang where I was needing to go when I am back and forth from Idaho to Utah. Too bad the pics don't do justice to some of the minor body damage, hence the motivating factor in spending a grip to repaint.
I understand washing, taking care of, and babying your truck as these are all things I do as well, but let's not forget why we bought these things in the first place. If your not using it, then there is no reason to make all of these kinds of adds in my opinion.
10-08-2011, 03:54 AM
Yah, I saw your pics on that a while ago before I picked up the spare carrier, so I was trying to find a solution to that before I got the spare carrier as I had concerns about whether it would fit the 40" or not. Didn't want to go roof mount because I was packing on the roof before I got the new rack and didn't like hearing the spare bouncing and shaking around up there. Also didn't like the pressure I saw it putting on the rack itself.
I ended up getting this swing arm off of a friends '08, $100, so you know I couldn't pass that up. Problem now is finding someone that can fabricate and do a clean job like yours because I really don't like how low it sits, looks kind of stupid.I also wanted to place a slight slant on it towards the vehicle. My offroad shop here does not fabricate so I am taking the time to find a decent shop. Had to do so much modding on my own with stuff already that I don't want to get into it unless it is going to be durable and clean. I have more modding yet that needs to be done so if you know of a good shop in my area, pass me a name.
BTW, love the rig man; nothing like a real man's Hummer.
10-08-2011, 01:18 PM
H2Much,
How did you get enough clearance to fit the 40" tire on the stock swingarm? I needed spacers to fit my 38X13.5" Toyo. I'm assuming your's is 15.5" wide?
Thank you,
Charles
10-08-2011, 04:07 PM
Originally Posted by H2Much
Truck looks KILLER!!! Treehugger looks incredible and those 40's are beast!! Keep up the good work!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
10-08-2011, 10:33 PM
Charles, I don't really know what to say about that. I had a major concern with the wheel and tire fitting before I got the swingarm, so I was looking around for a special one to accomodate. When my friend picked up his '08, he said he didn't want the swingarm. He had 37's on there and said it fit no prob, so I took him up on it. When I went over to get it we through my 40" on there and it fit perfectly, no problems at all, so I can't really say what the deal is unless it is the offset on the rim.
And yes, the tire is 15.5" wide, so it really must be the wheel offset I am thinking with those rockstars. Other than that, no modification to it at all.
It is also possible that they changed the swingarms in the later year models to accomodate larger tires, but I am not sure. I would go and ask a Hummer dealer, but they are extinct.
10-10-2011, 06:56 AM
05 SUT Pewter metallic,Black Ebony interior,11inch Headrest monitors with dvd,Punch amp and 10"sub,all marker lights smoked,chrome grill guard with KC daylighters,dual exhaust with 3"Flowmasters,Limo tint all windows,Bed cover,aluminum differential cover,6"Skyjacker lift,20x10 Fuel rims,38"toyo tires,taillight covers,bumper light covers,spare removed,Aamp research power boards,lots of other misc stuff..
10-10-2011, 08:09 PM
man you guys got me wanting to lift my hummer more. i only did the front leveling kit, and im working on throwing some 37's on the stock 17's. not even worth putting up pictures with these guys rides.
10-11-2011, 12:05 AM
Lift it!!  Mine is just sitting on a truxxx lift right now with 35's..but hopefully going up soon!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
10-11-2011, 02:58 AM
well, i have the chevy green torsion keys for the front to raise it about 2", and i was thinking of doing spring spacers for the rear. just to lift the rear about 2 more inches. that with the 37's, i think that should give me the look im wanting. and new shocks off course
