11-05-2011, 04:40 AM
shocks???
maybe its me but ive searched all over and cant seem to find what size shocks are needed. i have done a torsion level on it and im not sure which shocks i should buy. im thinking bilsteins or rancho. which ones do yall recommend?. im looking to make my h2 ride better and handle smoother in turns im also upgrading my steering. thanks
06 H2 SUT
-gobi ranger rack
-4 piaa 520
-hummer double brush guard
-vision x rock lights
-5%tint all around
-dual "whips"
-leveling kit
11-05-2011, 08:32 PM
Re: shocks???
check out ranchos web site. they have a kit specifically for leveled h2's. the rs5000 shocl. they also have steering stabilizer also. thede are the same shocks im going to be going with also.
2012 Porsche Panamera 4
11-06-2011, 03:37 PM
Re: shocks???
I have! All I see is stock, 4 inch lift, and 5-7. I think... but that is for r9000xl. Which I would like as they are adjustable
06 H2 SUT
-gobi ranger rack
-4 piaa 520
-5%tint all around
-dual "whips"
-leveling kit
11-06-2011, 07:56 PM
Re: shocks???
I have the same problem. I just put on 37" inch Nitto terra grapples and I have some rubbing. So I want to do a leveling kit with new shocks. Which ones do I get?
11-06-2011, 08:40 PM
Re: shocks???
skyjacker makes shocks too. but rancho has a kit just for leveled hummers. now if your wanting adjustable...i cant help you there. why do you want an adjustable shock on a levelled hummer?
11-06-2011, 11:36 PM
Re: shocks???
it would be nice to be able to dial in what i want, may just go with 500's but it im ever towing something tightening the rear shocks would be nice!
06 H2 SUT
-gobi ranger rack
-4 piaa 520
-5%tint all around
-dual "whips"
-leveling kit
11-06-2011, 11:38 PM
Re: shocks???
death, i am leveled, i bought a cheap kit off ebay with new keys and new shock brackets, there have been on over a year and are holding up just fine, if you just want to get rid of the scrub try cranking the t-bars. if that doesnt get rid of it all then go to new keys to gain a little extra height. but mine rides like pure poop now! it is soft. but body roll if crazy in turns!
06 H2 SUT
-gobi ranger rack
-4 piaa 520
-5%tint all around
-dual "whips"
-leveling kit
11-07-2011, 12:48 AM
Re: shocks???
sounds like what you need is some sway bars.
11-07-2011, 03:05 AM
Re: shocks???
im thinking extended bump stops and shocks will help alot! if not ill add a stronger sway bar, i just cant find what bumb stops to get!!!!
06 H2 SUT
-gobi ranger rack
-4 piaa 520
-5%tint all around
-dual "whips"
-leveling kit
11-07-2011, 02:15 PM
Re: shocks???
It rides like poop with the leveling kit??? Right now with out it , it seems a little hairy when I make some turns..Maybe Im not used to the new tires, (dont know).
11-07-2011, 09:49 PM
Re: shocks???
Look into the Cognito GM 8-Lug Upper Control Arm Kit (UCAK100001): http://dmaxstore.com/index.php?main_...roducts_id=324
Couple that with the Bilstein/Cognito Front Shock (BILSTEIN-BE5-E381-T0) and you'll get a nice ride that won't be compromised if you crank the torsion bars a bit.
CNTRY
DTOM
11-09-2011, 12:36 AM
Re: shocks???
i was paying attention to it today... its not as bad as i think, my steering though is wandering and a little hard to control... plan on a pitman idler support, and new tie rods. maybe new torsion bars cause mine a a tad worn out... we will see
06 H2 SUT
-gobi ranger rack
-4 piaa 520
-5%tint all around
-dual "whips"
-leveling kit
