11-01-2011, 06:21 PM
Re: LIFTED HUMMERS THREAD!!
Originally Posted by atomicgoofball
Discounttiredirect is where I got mine and they are awesome!! Fast delivery great Service and they price match/beat anything u can find!
they dont have much selection in a 37x13.50x20.
2012 Porsche Panamera 4
11-06-2011, 06:29 PM
I personally think the 13.50's would look better than the 12.50's in 37's. Perfect height to width
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
11-06-2011, 08:44 PM
ive deciided to go with toyo open coutry mt 37's. gonna wait for spring though
11-07-2011, 03:10 AM
Great choice..excellent tires
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
11-12-2011, 04:23 AM
Well thought to submit my 03 supercharged rig.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
11-12-2011, 04:25 AM
Shiny!
CNTRY
DTOM
11-12-2011, 01:44 PM
anyone have pictures of a rancho kit with 38's? this is the new combo im thinking of going with. wanted to see if their any concerns or tips.
11-12-2011, 02:49 PM
Originally Posted by guruerror
Shiny!
Must have been the angle of the lens.  The wife wont let me get a new camera, sorry...
2013 Sierra Denali
2012 Yukon Denali
11-15-2011, 05:04 PM
Originally Posted by 2010_5thgen
with a 20x10 wheel and -25 offset, should i go with a 37x12.50 wide or 37x13.50?
Fabtech's website lists the correct backspacing needed for their kits. I understand you're not using Fabtech's kit, but it might give you an idea of what to look for. Again, everyone is looking at offset only, and I understand it's what wheel manufacturers list, but we should be looking at backspacing AND offset. If you find a wheel you like, call and get the specs. A 10-20 minute phone call can save a lot of hunting around and headaches later...
There is also a tech article on another website (don't think I'm allowed to post it here) that describes the requirements for the Fabtech lift. PM me and I'll direct you there.
I keep thinking of things to add. When I purchased my truck, the previous owner had 37's with 22" wheels, and they rubbed. I changed to 38's on a 20" wheel, and avoided rubbing my sways by changing to a correct backspacing. I also lifted my truck a bit more, but that has nothing to do with the sway bar issue.
11-15-2011, 05:14 PM
Fabtech pushes the front wheels out further than the Rancho. Just call em they are very helpful. Rancho Suspension: Contact Phone Number - 1 734 384 7804.
11-15-2011, 05:28 PM
i had already talked ot rancho. they just said they tested their kit with a 5" backspacing on a 17x10 wheel with 37x12.5 tires. my new wheels are 20x10 with a 4.5" backspacing, so i should be good. ive also decided to go with a 38x13.50 toyo open country MT tire. with the amount of backspacing i have, i shouldnt have a problem with rubbing.
11-15-2011, 06:15 PM
I may be selling my Toyo 38's on KMC Hoss 20's and stepping up to 40's (damn Bimmer...). Interested? Or did you already place an order?
11-15-2011, 07:31 PM
i already have the wheels. just need the tires now. thanks though. got any pics though?
Not only hours of headaches but thousands of dollars of wasted money.
....cause we've all wasted a bunch of money trying different stuff only to find out it didnt fit or look as good as we thought it would, right???
Right?
Mark
11-15-2011, 07:44 PM
Right.
I'll have to post some pictures when I get home. Not sure if I have any updated ones, though.
11-15-2011, 09:24 PM
I'm only on my fourth set of wheels (one set I got from you Mark).
11-15-2011, 09:30 PM
My second set of rims, with Truxxx keys and spacer... LAME!
11-15-2011, 09:48 PM
i had a escalade before my hummer. went through 4 sets of wheels on that. with my camaro, this is my 2nd set of wheels in less than 2 years..... its addicting. after i do the lift on the hummer, not only did i just buy new wheels for 38's, but ill have to buy new wheels to run in the winter since the stock wheels wont fit with the rancho lift.......i love spending money. lol
11-17-2011, 10:44 PM
Just wanted to clarify some mis-information I posted earlier. I was correct on backspacing being measured from the inner lip/back of the wheel to the hub. But offset is measured from the center of the wheel, NOT the hub, to the outter lip/front of the wheel. Essentially, the dead center of the wheel is a 0 offset, and a -12 offset moves the hub closer to the inner lip/back of the wheel. A +12 offset would move the hub closer to the outter lip/front of the wheel. Hope I cleared up any confusion I caused. And I didn't want to look like an idiot.
*By "hub" I'm referring to the part of the wheel where the lug nuts go, not the hub on the truck.
11-18-2011, 09:03 PM
Time to hit the mountains!
2008 Hummer H2 SUT
Greystone Metallic, Rancho 4" Lift RS9000XL, 20" XD Badlands Rims, 37x13.5x20 Toyo Open Country MT, AFE Cold Air Intake, BlueFusion Bluetooth, Flowmaster Dual Exhaust, Warn Winch 9.5Ti Multi, Gobi Rack, Baja Rack Duel Can Carrier
1995 Dodge Viper
Emerald Green, 18 & 19 5 spoke Rims, Autoform Hardtop
USAF (Retired)
