  #141
Old 11-18-2011, 09:09 PM
guruerror's Avatar
Default Re: LIFTED HUMMERS THREAD!!
Originally Posted by DeLH2
Time to hit the mountains!
I like those SUTs so much better with the rear tire delete! Nice!
Do you carry a spare at all?
CNTRY
DTOM
Old 11-18-2011, 09:16 PM
DeLH2's Avatar
DeLH2 DeLH2 is offline
DeLH2 is on a distinguished road
Not at all, I'll throw the spare tire carrier back on only if I'm going for long trips, other than that the spare stays in the garage....
2008 Hummer H2 SUT
Greystone Metallic, Rancho 4" Lift RS9000XL, 20" XD Badlands Rims, 37x13.5x20 Toyo Open Country MT, AFE Cold Air Intake, BlueFusion Bluetooth, Flowmaster Dual Exhaust, Warn Winch 9.5Ti Multi, Gobi Rack, Baja Rack Duel Can Carrier
1995 Dodge Viper
Emerald Green, 18 & 19 5 spoke Rims, Autoform Hardtop
USAF (Retired)
Old 11-18-2011, 09:19 PM
guruerror's Avatar
Too bad we can just throw them on the hood like the old Landies.
CNTRY
DTOM
Old 11-18-2011, 09:24 PM
DeLH2's Avatar
I was debating whether to get the Gobi's Tire carrier for the roof, but it will be a task to mount and unmount due to the size and weight I have to mess with...
2008 Hummer H2 SUT
1995 Dodge Viper
USAF (Retired)
Old 11-18-2011, 09:58 PM
guruerror's Avatar
At least with the SUT you can stand in the bed...that would make it easier then getting the tire on top of an SUV.
I could have swore that I saw someone on the forum with a slantback spare tire mount on their H2. I can't find the thread or a pic anywhere now. I recall the pic was of a black SUT with a lift and custom bumpers...I don't know, but it was similar to this:
EDIT: Found it...http://www.elcovaforums.com/forums/s...ight=body+lift
CNTRY
DTOM
Old 11-18-2011, 11:13 PM
DeLH2's Avatar
That looks pretty sweet, the closest I can find and possibly modify are these. Just get a good welder and fabricate a carrier in between the post.
2008 Hummer H2 SUT
1995 Dodge Viper
USAF (Retired)
Old 11-18-2011, 11:19 PM
guruerror's Avatar
Welders typically aren't that expensive...
...then get it powder coated and call it a day.
A local welding shop charged me $75 to mod my stock carrier to lift the tire up. http://www.elcovaforums.com/forums/s...hlight=carrier
You just need a couple cross bars and a mounting point; which you could have cut from your stock arm...dunno...food for thought.
CNTRY
DTOM
Old 11-19-2011, 03:27 AM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Truck looks good!!!
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 11-19-2011, 04:23 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
The company that does most of my work moddified one of the above pictured bed bar set-ups to carry a spare. The guy had it on for a couple of years, but ended up ditching it because it rendered the bed useless.
I disagree with most of the opinions here. I like the look of the rear tire carrier. Without it, the truck looks too short, almost like someone smooshed it.
Old 11-20-2011, 12:44 AM
tyler1bo's Avatar
I see your point but I personally like the fact that I don't have to swing my spare carrier open everytime I want to drop the tailgate. Plus I think it makes the truck seem wider gotta love fat rear ends. Well..to some extent. But it's all personal preference!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 12-30-2011, 01:47 AM
tyler1bo's Avatar
I can finally be added to this list! To keep this thread going, here's my Rancho/Truxxx lift..
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 12-30-2011, 01:59 AM
Bimmer9938's Avatar
Looks awesome! Cut those bump stops off the front shocks, you'll never bottom them out.
Old 12-30-2011, 02:02 AM
Awwww, what a cute little truck...
Seriously, dude, that looks GREAT! What size tires? Makes me wanna put black wheels on mine.
Mark
Old 12-30-2011, 02:09 AM
Bimmer9938's Avatar
I read 38's, and Mark you should do some black rims... did you ever get your 40's Mark?
Old 12-30-2011, 02:15 AM
I really wanted the Octane fuels in black, I think they?re hot...
I did get 40?s on.
Mark
Old 12-30-2011, 02:18 AM
Bimmer9938's Avatar
Nice Mark, are they rubbing? Mine rubbed like crazy with 12" wide wheels.
Old 12-30-2011, 02:24 AM
The only time they rub is if I have the wheel turned all the way to the right and go in reverse, you can juuuust hear them rub. You would think if they rubbed, they would rub in either direction.
... but like I said, haaardly.
So you?re not running 12?s? How wide are you running?
Mark
Old 12-30-2011, 02:27 AM
Bimmer9938's Avatar
I do run 12's, so they would rub more when turning then your 10's. Yea mine would catch the fender liners in reverse so I had to trim a lil off. Plus the Super Swamper is a true 40" measuring 40" which doesn't help.
Old 12-30-2011, 02:40 AM
tyler1bo's Avatar
Mark
It's not little anymore! just a little smaller than yours at the moment! And yes they are 38X13.50...You really should change to black wheels!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 12-30-2011, 03:06 AM
My rims are 12?s...
And the 40?s measure like 39.7? tall when I measured them.
Mark
