01-20-2012, 08:17 PM
5th wheel license plate?
I currently have the stock 5th wheel spare on the back of my hummer. But since I did the lift and changed wheels I now have a 20" wheel with a 38" tire. Where do I put the license plate? Will it mount up in front of the wheel like it does now or do I need to move it? Iv seen some that have the plate mounted to the right of the tire on the bumper. Is this a kit or something? How should I mount this?
2012 Porsche Panamera 4
01-20-2012, 08:25 PM
Re: 5th wheel license plate?
I've seen it done a thousand different ways..I have mine on the bumper. Just bought the RealWheels license plate kit that bolts on a hook. But you can put the license plate inside the new wheel on the back.
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
01-20-2012, 08:28 PM
How does it bolt to the wheel of I decide to keep it where it is? And did you have to drill holes in your bumper or run lines for lights on the mount on your bumper?
01-20-2012, 08:49 PM
One of these may work..
http://www.ebay.com/itm/Genuine-GM-H...ht_1375wt_1348
And no I didn't have to drill anything on mine.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
01-20-2012, 08:59 PM
I have one of those on my spare cover now. Is that all I need?
01-20-2012, 09:03 PM
I'm not 100% sure but I think that's it..like I said you can do it a hundred different ways. I've seen guys just drill into the bumper and hang it, weld it to a hook, etc. I just took the easy way and ordered the RealWheels kit.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
01-20-2012, 09:45 PM
I screwed mine straight into the bumper on the right side, just below the swing out tire carrier, then had my shop mount a light on the carrier that shines onto the plate. Works great!
01-21-2012, 02:09 AM
I made a hitch bracket and a flat steel plate and put it in the trailer hitch. I put a led plate light on top of plate. Looks really good.
01-21-2012, 02:12 AM
Got any pictures
01-21-2012, 02:15 AM
send me a pm with your phone number and i will send it to ya
01-21-2012, 05:36 PM
My truck had it in the trailer hitch as well when I bought it. But I quickly realized that if you tow anything, you're out of luck.
02-01-2012, 09:52 AM
http://www.ebay.com/itm/320609948211... 4.m1423.l2649
If you want to not take away from the pretty spare. The center bore of the tire carrier is kinda long, I cut it down when I used to use a fancy spare on my second H2.
02-01-2012, 09:55 AM
Also ran one of these once, if you don't use your truck for towing, but if you wanted to put a hitch step on, I'd use the style above.
http://www.tomken.com/detail.php?id=165
02-01-2012, 09:58 AM
My current set up, just welded a piece of steel stock to the tow hook and got a cheap plate light.
02-01-2012, 02:02 PM
those pictures, do they have a light run to the plate?
02-01-2012, 05:22 PM
Attached a little piece of angle iron to the bumper, then mounted the plate right to it...no light, though; but wouldn't be hard to rig one of those up considering the wiring for the trailer is right there in the bumper.
CNTRY
DTOM
02-01-2012, 09:01 PM
hmmm... desicions desicions....
02-01-2012, 09:05 PM
I painted my plate light black, I ordered it at a truck store it was a whooping $8.00
02-01-2012, 09:14 PM
She makes an excellent plate holder!
CNTRY
DTOM
02-01-2012, 09:33 PM
I'll tell her that... lol.
