Old 03-01-2012, 09:45 PM
guruerror's Avatar
Default Re: 37x12.5x17 on stock rims
Originally Posted by 2010_5thgen
looks good. you need some for that trailer now.
Thanks.
Yeah...almost pulled the trigger on that when I did the spring over conversion, but just had them painted black for the time being.
CNTRY
DTOM
Old 03-01-2012, 09:58 PM
Indy's Avatar
Indy Indy is offline
37's should have been on the H2 from the factory. They would only have needed to mod the frame a little bit to make them work without any rubbing on full lock....the stock size is just a bit too small for the big dimensions of the H2.
Old 03-02-2012, 02:45 PM
jsbihn jsbihn is offline
Moderator
I had a feeling guruerror would have a pic
Definitely the way to go
I know when I finally get ready for new tires on mine, I will be doing the 37s
I am curious if a small spacer would eliminate the rubbing (if you have that) on full lock
Old 03-02-2012, 02:50 PM
guruerror's Avatar
I had a slight rub at full lock with the stock rims. A small spacer would more than likely eliminate the rub. I have no rub at all with my RSs...but the back spacing is an inch less, so there's less wheel under the truck.
CNTRY
DTOM
Old 03-02-2012, 02:57 PM
Moderator
Yeah I am not a fan of big spacers or generic spacers.
BUT I do think that if you want to get the look without reworking the wheels (stock or otherwise), then it is ok.
Given I am not saying you are saying to do it, I wouldnt put a 1 inch spacer on my wheels.
With that said, truck is bad ass........................ as usual
Old 03-02-2012, 05:00 PM
KT2T's Avatar
KT2T KT2T is offline
KT2T is on a distinguished road
Ok, what's hanging off your spare in this pic? It's just far enough away to see but not know... and now I must know!
I noticed in a previous front/driver-side pic what looked like a bit of a bike tire peeking around the corner, so perhaps a spare-mounted bike rack? If so, which rack?
Thank you sir!
Originally Posted by guruerror
Mike
2000 HUMMER HMCS, kevlar flat black, Rubber Duck lift, Predator stage 3 kit, Predator (Wilwood) Big Brake kit, a work in progress...
2008 H2, graystone, air suspension (DELETED), U-steps, SMA brushguard w/valance (DRLs replaced by PIAA 520s), black taillight guards/locking fuel door/roof crossbars (x4), Cognito UCA/pitman-idler, Bilstein shocks, Rancho steering stabilizer, Kryptonite tie rods, green keys, Fuel D525 20" Revolver, 37" Nitto Ridge Grappler
Old 03-02-2012, 07:01 PM
guruerror's Avatar
Thank you sir!
Yep...it's a bike rack. I started with a Hollywood SR1 spare tire rack that I picked up at the a local bike shop.
http://www.amazon.com/gp/product/B00...SIN=B000QJDFMK
The problem was that it would BARELY fit over a 37x12.5 and it wasn't tall enough for the bottom of the U to rest against the tire for support. It worked, but I was constantly worried about it, especially when carrying two bikes; and I never would have taken it out on the trail with a bike loaded up.
SO, I went to Home Depot and and hit the plumbing section up for some 3/4" pipe, couplers, and elbows and built my own 'TRAIL RATED' rack. I kept the square crossbar from the Hollywood rack because I liked the collapsible arms and rubber tie-downs. I simply mimicked the overall design of the Hollywood rack, but on a larger scale. It's designed to snug right on a 37x12.5...perfect...solid as rock.
Once I had it assembled I dropped it off a Rudy's Welding and Cold Beer (Middletown, MD) to have all the joints welded, the rack powder coated, and pick-up a six pack.
...and that's how that got done.
...and here's Rudy's...LOL...
CNTRY
DTOM
Old 03-04-2012, 06:26 AM
Moderator
What the heck. I thought we had some weird combo businesses in the south (ie. pool hall and chicken, or used tires and bbq)
But this wins in my opinion
