03-05-2012, 02:34 AM
new member
05,way more fun than i expected,been reading thru the previous posts,good informative site.... Attachment 53767
03-05-2012, 04:45 AM
Re: new member
Welcome to the forum! Nice lookin ride you have there..any plans for mods?
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
03-05-2012, 01:51 PM
Re: new member
thanks,i have removed brush guard,luggage rack,rear tire carrier,chg'd all fluids to synthetic,found the 2 broken manifold bolts,the rear one on each side,soaking in bp blaster,but to answer your question,yes a couple of things,dechroming a little,thinking about a different wheel/tire setup...is there any advantage to these 20" wheels other than the look,17"tires are alot cheaper,i suspect tires alittle closer to stock size may improve mpg,i'm getting 13mpg on dic,12.8 on calculator,so that may be as good as it gets i don't know
03-05-2012, 02:07 PM
Re: new member
 Congratultions! You're going to love it! Welcome.
03-05-2012, 02:16 PM
Re: new member
I don't think you will see much if any improved gas mileage with the 17's, plus most people want to get rid of the 17's and go to 20" and up anyway... The pic you posted is small, but your rims you have on now seem to be nice. I wouldn't get rid of them, one thing you got out of the way for mods and don't have to worry about...
03-05-2012, 02:43 PM
Re: new member
it rides great with the 20"wheels,tires are like new nitro's,so there's no hurry to chg them,for now just going thru it fixing what i can,with 50k on odometer i hope theres not too much wrong....
03-05-2012, 03:04 PM
Re: new member
I agree s_c5519, you won't see much better gas mileage than what you've reported. It's more the weight of the wheel (tire + rim) that impact MPG; if it weights more, it's harder to turn. As you read around you'll find that 12.8 is a pretty high number for these trucks.
Regarding 'advantages' of 20" rims...I'd say 'street looks'. If you're planning on off-roading then I'd say go with a smaller rim size...more rubber, less metal.
CNTRY
DTOM
