04-16-2012, 02:37 AM
Re: Gas milage help!!!
Originally Posted by tyler1bo
Wouldn't a regear help? Like 4.88's?
4.88 will be less gear than stock ratio setup, 5.13 would be a little more. It would make a major improvement. I'm sure it feels like a lazy pig right now.
Honestly this rig in question is going to need $6000-10000 in additional parts to get it to drive as stock or better. Gears are $1000, Install for gears runs anywhere from $800-2000. Although not mentioned, there is no way that truck brakes now like it should now. Big Brake kits on all 4 corners start at $5000 if you get lucky. No way any of the stock steering is going to hold up for any decent amount of time. At a minumum, $1500 in steering components. To do everything your around $3500.
I really think that anyone that sells/installs lift kits should thourghly go through w/ the buyer all the additional work that will need to be done after the kits are installed. The lift kit ends up being the cheap part when you have to upgrade all these other components.
Im in the middle of putting 5.13's in my rig and im currently running 37" tires.
04-16-2012, 02:59 AM
Your absolutley right, pre cat o2 sensors monitor and adjust fuel trim but when the post cat sensors are not in the picture it puts the system into open loop operation and runs in a base fuel model which is always rich mixture.
1998 Chev Z71
2007 Chev Trailblazer SS
04-16-2012, 05:19 AM
Ive got a buddy that installe numerous gears in older card and specifically 9" fords. He's very good installer and he thinks he does not want to tackle the gears in the h2... He days he's not Forster but in some later model gm trucks you have to use a case splitter... It essentially stretched the whole bigger to get the guys out..... Anyone know if this is required on the h2s? If not we can install my gears and save me a ton of $$ . I called a well know shop and try want 2g for 4.88 installed and give me no warranty! Which I think is bs.... As far as brakes go... It's not bad, not the best but not bad.... I pull a 16ft landscaping trailer 75% of the time too... You just gotta b a smart driver.... As far as steering componets.... My front end shop assures me these front ends r not junk and can handle these wheels and setup I have.... I don't offload this truck so it's not abused by anymeans.... They suggest I keep everything lubes often and I will b fine.... They suggest I keep my stock front end until I get some wear in them before I go upgrading things.... Kits been on for 12,000 mi now and no wear yet... Only had to retighten the lift kit bolts...
04-16-2012, 05:20 AM
And on the sims for the cats, any clue where these guys are buying them from? They r getting hard to find.
04-16-2012, 02:35 PM
Actually going from a stock 35" tire with 4.10s to a 40" tire would require a 4.69 ratio to keep the stock ratio. Since they don't make a 4.69 you could use a 4.56 (shorter than stock) or a 4.88 (taller than stock). A 5.13 would be way taller than stock gearing...and crazy tall running 37"s.
You can find AP Racing BBKs for roughly $4,500 front and rear if you look...and APs are just as good, if not better, than Brembos. It's the route I'm going when I put the 10-12" Cognito and 42"s on mine. But as you've mentioned previously, any lift that uses a new steering knuckle may require some creativity to mount.
Agreed...$700 for the Kryptonite steering link and tie rods, $225 for the Cognito pitman and idler support brackets, $215 for the Cognito idler pivot kit and it'd be wise to upgrade the steering box and pump as 'OrangeCrush' did to his truck. An easy $1,500 to do it right provided you can do your own labor.
Agreed...if you want to do it right.
That's some steep-ass gearing...but not a bad idea if you plan on running bigger tires at some point.
All in all, some good advice for anyone considering lifting their truck and thinking they can bolt on a lift to the tune of $5-6,000 and be done with it. A whole lot of other things to do that most people never even give a second thought to.
04-16-2012, 02:39 PM
You should try calling Randy's Ring & Pinion's tech line...they can tell you what's needed with a gear change in the 9.5 AAM and can also give you pricing on the gears front and rear and all of the other necessary items (shims, crush sleeves, etc).
04-16-2012, 06:43 PM
[quote=Humdingah]Actually going from a stock 35" tire with 4.10s to a 40" tire would require a 4.69 ratio to keep the stock ratio. Since they don't make a 4.69 you could use a 4.56 (shorter than stock) or a 4.88 (taller than stock). A 5.13 would be way taller than stock gearing...and crazy tall running 37"s.
I already had 4.56 gears in my truck when I bought it w stock wheels/tires. Maybe thats why I felt so much of a loss jumping up to 37's. I'm hoping w/ the extra torque I'll need less throttle which should keep it in overdrive more on the highway.
04-16-2012, 07:08 PM
Use spark plug anti foulers to remove the CEL.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
04-16-2012, 07:26 PM
Originally Posted by '[__--MUD--__
'I already had 4.56 gears in my truck when I bought it w stock wheels/tires. Maybe thats why I felt so much of a loss jumping up to 37's. I'm hoping w/ the extra torque I'll need less throttle which should keep it in overdrive more on the highway.
04-17-2012, 08:46 PM
Doesn't always work though. I would get the rear O2 sensors programmed out of the ecu for a permanent solution.
04-17-2012, 09:49 PM
Why not just put some high-flow cats in and call it a day?
CNTRY
DTOM
04-18-2012, 12:11 AM
lifted 8" with 40" mud Trappists and 20x12 fuel rims. The tires are 15" wide as well. This is all in town milage for the most part
^ that will do it!
Sold!!! 2009 H2 SUV Graystone Metallic. Next stop, 2006 H1 Alpha Hard Top
04-18-2012, 03:31 AM
tell mw this which one is cheapest? lol i can do all the labor on any of them but im sure the sims r prob the cheapest???
04-18-2012, 06:22 PM
Last time I bought o2 sims it was couple hundred bucks, but its been a while. o2 sims would be a bandaid and most likely trigger an occasional check engine light, editing it out of the ecm would be the fix.
04-18-2012, 09:27 PM
Anti foulers. Programming your ECU and sims would be next step of course if for some reason the anti foulers don't work. But at $10 it's worth trying the anti foulers first. I have been utlizing them on my H2, Z06, Viper, and BMW and all they have all been running fine for years now with no CEL.
2005 Black LUX
37x13.50R17 Toyo MT
2" wheel spacers
Bilstein stabilizer
04-19-2012, 03:37 AM
whwre can i get these for the 6.0
04-19-2012, 04:13 AM
My gas mileage has went from an unmovable 11.7 to all of a sudden 12.5.... knock on wood
