05-22-2012, 05:23 PM
DRL Mod on 09 H2
I have a 09 H2 and want to do the DRL MOD with the diode.The only proablem is, I can not find the radio shack one-PN-276-1102-1 amp,220 volt- at any of the Source stores,in London Ontario,Can.Radio Shack is called that here.Some electronic shops in town have 1000 volt,1 amp diodes,but not the 200v,1 amp.Will the 1 Amp-1000v one work,as long as it 1 amp,or is this gonna fry something in the fuse box.I know nothing about diodes and how they work,so I thought I woulk ask the experts here first before I do anything.Thanks...
05-22-2012, 08:18 PM
Re: DRL Mod on 09 H2
CNTRY
DTOM
05-22-2012, 09:40 PM
Ha Mr. LineX that is some link, never seen that done before AAAA++++
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
05-22-2012, 09:44 PM
I found a 50 volt 1 amp micro diode at a little electronics store near me.Wonder if this will work..
05-22-2012, 09:53 PM
I'm pretty sure any 1A diode with a peak inverse voltage greater than 12-15v will work just fine.
So your 50V jobby should do the trick...
CNTRY
DTOM
05-23-2012, 01:25 AM
Yes the higher voltage capacity one will work. It's like using a larger gauge speaker cable than what you need.
05-23-2012, 02:23 AM
I picked up the 50 volt 1 amp one.I will hook it up tomorrow and post how I made out.Thanks all for the info..
