Old 06-21-2012, 05:24 AM
pdxrealtor's Avatar
Default Where are the cooling system bleeder plugs?
Doing a cooling system service and the manual says to loosen the cooling system bleeder plugs.
Does anyone know where they're at??
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 06-22-2012, 07:02 PM
pdxrealtor's Avatar
Default Re: Where are the cooling system bleeder plugs?
No one knows??
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-22-2012, 10:48 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
I have never heard of cooling system bleeder plugs in all the years of working on vehicles. There is usually a drain petcock at the bottom of the radiator but I don't think that's what you're looking for.
If you need to bleed the coolant system that's just done using the radiator cap.
Old 06-22-2012, 10:53 PM
pdxrealtor's Avatar
Thanks for your reply.... I never seen them either but on the ******* site a guy had posted instructions out of the service manual.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-23-2012, 12:01 AM
Easy Ed Easy Ed is offline
These Plugs ?
Old 06-23-2012, 12:21 AM
pdxrealtor's Avatar
Originally Posted by Easy Ed
These Plugs ?
No those are the engine block drain plugs. In your manual under the fill procedure it should mention the bleeder plugs no?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-23-2012, 12:30 AM
First pic and part of second one is about the drain and fill of the coolant system, no mention of drain plugs except for the engine block ones.
Edit: Number 6 is the only mention of a "drain cock".
Old 06-23-2012, 01:02 AM
pdxrealtor's Avatar
Check it out...
Found here.... http://www.*******club.com/forum/vie...hp?f=3&t=11337
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-23-2012, 01:14 AM
I think my 3 and 6 in the Draining and Filling Cooling System pic are the same as your 6 and 8 in the Filling Procedure pic of yours, just a different name for the same item ???
But re-reading it I am not sure why it would want the drain (bleeder screws) opened before putting in the coolant ???
Side note, my manual is a 2003 H2 Helm one.
Old 06-23-2012, 01:22 AM
pdxrealtor's Avatar
Ya Im not sure....
Thanks for posting that up though.
FYI for anyone else that comes along I drained, filled, drain, filled twice. Just left the cap off as mentioned above.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-23-2012, 01:27 AM
Ya sure those instructions are not for a H1 ? These instructions show "air bleeder screws".
Just a thought while I am trying to help and google for some info
Edit, nope they (yours) are for a H2, now I am more confused................
http://www.flashoffroad.com/Maintena...e/ChgAntif.htm
Old 06-23-2012, 01:41 AM
pdxrealtor's Avatar
I'm not sure just got them off the site where a guy with an 04 h2 was asking. See my link above for thread.
I was thinking the same as you.... It's possible the person posted for the h1 not paying attention to the type of truck the poster had.
That Link you posted is for an h1 it seems. I did come across it in my searches but skipped when I saw the diesel and 6.5 liter mentioned.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-24-2012, 04:37 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
I just remove the lower radiator hose, drain, and refill with 50% DexCool and distilled water. I have a fleet of vehicles and do this every 5 years or 100k miles. I've never had to flush or have had any water pump, radiator, or freeze plug issues. It's when all of the anti corrosion properties of the antifreeze get used up is when you start to have problems.
Old 06-24-2012, 08:58 PM
pdxrealtor's Avatar
That's what I ended up doing but I did fill with water and run through the system a couple times.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
