Old 07-03-2012, 12:56 PM
SMITH23H2SUT's Avatar
SMITH23H2SUT SMITH23H2SUT is offline
SMITH23H2SUT is on a distinguished road
Angry What the heck is this sound?
"http://www.youtube.com/embed/EOOtwsbtYw4"
Old 07-03-2012, 01:15 PM
Joe Joe is offline
Joe is off the scale
Default Re: What the heck is this sound?
almost sounds like a broken exhaust manifold bolt. Check the rear one(s) drivers side. Sounds is a bit different then mine, which has this issue, but guessing that is the cause.
2001 H1 Opentop
2003 H2
Homepage:
http://www.hummerh1.net
Old 07-03-2012, 01:46 PM
From one Joe to another.LOL(We share the same name). Thanks for listening, I hope that's all it is.What about the Oil pressure? Is that normal?
Old 07-03-2012, 02:23 PM
guruerror's Avatar
CNTRY
DTOM
Old 07-03-2012, 03:44 PM
Joe Joe is offline
Oil Pressure? Not sure, no reference in video so not sure what your experiencing. In my case I have not seen a change to the oil pressure with the busted manifold bolt, certainly the sound you are experiencing.
if your seeing an oil pressure issue may be some other issue then the manifold bolt. Given the sound cadence with throttle check your belts, pulleys, and tension otherwise I''m guessing your in the motor and I'll leave that to far more knowledgable folks to troubleshoot.
2001 H1 Opentop
2003 H2
Homepage:
Old 07-03-2012, 04:35 PM
Hellz Hellz is offline
exhaust leak..
if you listen.. you can get the timing to it.
check your header bolts...
seems to be a rash of these popping up again
Old 07-04-2012, 04:32 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Make sure you get the updated header bolts from GM when you change them.
Old 07-04-2012, 09:56 PM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
I've got this sound as well.
Old 07-04-2012, 10:40 PM
ryaleon's Avatar
Actually just checked mine. Drivers side rear bolt on manifold was indeed loose. And it will not tighten. Looks like it's broken. Sigh
Old 07-05-2012, 11:43 AM
Ditto.Now I have an excuse to have my entire exhaust upgraded.Headers on back. Just have to find someone to do the work.
Old 07-07-2012, 05:46 PM
jsbihn jsbihn is offline
Moderator
I swear I must be jinx'ed
Seems like the minute someone on this forum has an issue, my truck gets it too.
Looks like I have a leak too. UGH!!!
If I didnt love this truck
