Old 10-14-2005, 01:35 AM
theadlee theadlee is offline
theadlee is off the scale
I am really interested in installing this unit in my H3. I would love to hear anyones experience with the fit of the device and other installation considerations.
I would like to understand if the Naviation control bypass while driving hack still works for this unit.
Thanks in advance.
Thanks in advance.
Old 10-14-2005, 02:53 AM
firm firm is offline
firm is off the scale
I just bought one, it arrived today. When I get it installed (hopefully this weekend), I'll take pics.
Old 10-16-2005, 02:19 PM
techray techray is offline
techray is off the scale
I installed the avic-N1. at least i think thats right. It had the fold out screen and all the options like nav, xm, av inputs, back up camera. well it wasn't too bad the key was to get the rigth parts like the onstar interface module and the correct pocket to hold the unit in the dash with out looking like dunn. I also had to modify there wiring due the onstar module. let me know if I can help.
Old 10-16-2005, 04:27 PM
Could you tell me what onstar module to get? Also, if there are any other parts I need, please let me know. Thanks.
Old 10-16-2005, 04:31 PM
4churchill is off the scale
i had the n1 in my '03 H2...good unit
for the h3 i say go witht the eclipse double din all day long. we have 4 untis in stock with it installed and it works great!!!! and looks good too
www.HUMMERNut.net
Old 10-16-2005, 05:55 PM
AVN2454 is a nice unit indeed. I am an XM Radio fan so that is why i am leaning towards the AVIC-D1 for the H3. I'm just trying to find someone who has installed one in a H3 to find out if there are any gotchas.
Old 10-17-2005, 02:20 AM
yeh I have all the names & numbers at work i'll get them for ya tommorw.
Old 10-17-2005, 02:17 PM
I tried to get the Avic-D1 installed last friday. I found out that I will need a tuner, and the Onstar connection. I checked ebay and got the nav traffic tuner for $114 (normally $330). The Onstar connection is the Onstar/Monsoon adapter OS4, but I've only found one company that sells it. I'm not sure if the OS1 or OS2 will work with out splicing wires. Check out 12volts warehouse for deals on the Avic-D1. I got it for $1065 with $300 rebate.
Old 10-17-2005, 03:51 PM
First Hummer is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by firm:
I tried to get the Avic-D1 installed last friday. I found out that I will need a tuner, and the Onstar connection. I checked ebay and got the nav traffic tuner for $114 (normally $330). The Onstar connection is the Onstar/Monsoon adapter OS4, but I've only found one company that sells it. I'm not sure if the OS1 or OS2 will work with out splicing wires. Check out 12volts warehouse for deals on the Avic-D1. I got it for $1065 with $300 rebate. </div></BLOCKQUOTE>
Firm do you know about connecting the purple wires toegther from the factory harness.OS-2 does work fine with aftermarket radio.There are either 2 or 3 purple wires in factory harness that need to be connected to each for the radio to work.
Old 10-18-2005, 02:53 PM
sorry a little late, the dash kit is a part #gm380 from american international and the annt. kit is #gm-6 also thru A.I. The on star interface module is # gm2h24 from perifrail. all of these parts Stereo King had in stock here in portland. also you will have to connect the two ppl. wires to the class 2 so it bypasses thru the radio and the amp power will be the radio acc. power or ing. source. gook luck! let me know if I can help at all.
Old 10-18-2005, 09:05 PM
Thanks for the info techray,
Firm, have you installed yet? I would love to see pics. Techray installed the AVIC-N1, I am leaning towards the AVIC-D1 to fill the double din.
I am about ready to pull the trigger. I found a price that seems too good to be true. $970 with no rebates.
http://www.pricegrabber.com/user_sales_getprod.php?mast...27647&lot_id=1940561
They have decent reseller ratings. Firm, where did you buy yours?
Old 10-18-2005, 09:38 PM
h3\'er h3\'er is offline
h3\'er is off the scale
D1 is a nice unit. I went with the N2 myself for the stealth look. Nothing says steal me morw that that double DIN unit sitting in there visible to the person peeking in your window.
Old 10-18-2005, 10:56 PM
Techray or anyone else that wants to chime in,
Are these the parts I need to install the AVIC-D1 in my H3?
Onstar Module
http://www.hifisoundconnection.com/Shop/Control/Product...9/vpcsid/0/SFV/30046
Dash Kit
http://www.millionbuy.com/aigmk380.html
Antenna Adapter
http://www.millionbuy.com/a-igm6.html
Old 10-19-2005, 03:24 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by theadlee:
Onstar Module
Dash Kit
Antenna Adapter
Thanks </div></BLOCKQUOTE>
This looks like a Re-badged Pac-Audio OS-2 adapter.
I paid around $90.00 for mine from x10.com
Here's the link for the Pac-Audio adapter
http://www.pac-audio.com/products/onstar.htm
you will also need the chime adapter if you remove the factory radio. part #cm1 at the bottom of the above link
Also that mount kit will not support a double DIN unit like the D1? Spec says its only holds max of double ISO mount radio. The D1 is a double DIN. Has anyone mounted a double DIN with one of these?
Old 10-19-2005, 03:48 PM
Onstar Module
Dash Kit
Antenna Adapter
you also need the CM1 module for the door chimes.
Old 10-20-2005, 03:55 PM
First Hummer,
sorry it took so long to get back to you. I think with the OS-4 you don't have to splice any wires, just plug and go.
The D1 should fit, I've seen the Excelon fit. The dash kit comes with the D1.
theadlee- I bought mine from 12 voltswholesale through ebay.
I'm still waiting for the tuner to come, then I will install it.
Old 10-21-2005, 02:27 AM
ok, sorry about the mix up I forgot the d1 was a double decker. have you got everything in order yet. if not I will get you the exact numbers for your unit. just beware the on-star modules may or maynot be a plug-in play. from what i have heard from multi people in the audio biz. Due to the fact the H3 is so new still. either way It is do able and easy. just gotta spend some time to get all the right parts first. sorry about the mix up !
Old 11-04-2005, 02:42 AM
kodiakz kodiakz is offline
kodiakz is off the scale
Don't know if you guys ever bought your D1's or N2's, but Pioneer just announced a $300 consumer rebate on both pieces until the end of the year. The D1 is a double din (same as 2 isos just not using a sleeve to mount) and will fit nicely in your H3 dash! Best kits makes a kit # GMK 422 that will mount it nicely with some easy modificaion (make your own tabs).
Old 11-13-2005, 12:42 AM
I got the OS-4 for the onstar adapter, it's plug and play. $99.95 at installer.com
