Old 08-23-2012, 10:53 PM
citiboy's Avatar
citiboy citiboy is offline
citiboy is on a distinguished road
Talking Upgrade Steering and Suspensions Parts
All the parts that i've ordered came in.....i'm goin' to install 'em this weekend.
Here's the parts list:
ARP exhaust manifold stud kit
AC Delco exhaust manifold gasket
Exhaust manifold donut
Torsion bar bracket support bushings
Cognito steering support kit
Cognito front stabilizer link kit
Cognito upper control arm kit
AC Delco rear stabilizer links
Moog inner and outer tie-rods
Bilstein front and rear shocks
Bilstein steering stabilizer
I have to deal with the broken exhaust manifold bolts on rear passenger side. Hopefully it'll come out without a fight .
Next mods will be to re-gear the front and rear diffirential with yukon gears 4.88 and also install front eaton e-lockers .
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
Old 08-23-2012, 11:16 PM
Hellz Hellz is offline
Default Re: Upgrade Steering and Suspensions Parts
wow... thats going to be a fun weekend for you..
Old 08-23-2012, 11:44 PM
citiboy's Avatar
yeah, hopefully it's goin' to be a smooth install.....the only things that worries me is that pesky broken manifold bolts .
Did you ever replaced your torsion key support bracket bushings...mine's are welded to the frame and i have to drill new holes for the replacement parts. When i replaced my TB keys, i've noticed the bushings so loose and caused clunking when suspension flexes.
Old 08-23-2012, 11:56 PM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Wow..That's a beautiful sight. haha. But hard work!
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 08-24-2012, 12:05 AM
citiboy's Avatar
LOL....btw, how do you like your rancho steering stabilizer? i'm tempting to get that but go with the bilstein instead, hopefully i made a good choice.
Old 08-24-2012, 02:18 AM
tomp's Avatar
tomp tomp is offline
You will want to add the cognito limiting straps to go with those control arms and shocks as this setup will cause front arms to hang on upper ball joint rather than the shock as the limiter, which casues premature ball joint failure. straps will cure it
Old 08-24-2012, 02:55 AM
citiboy's Avatar
Thanks tomp, this is a great info...i'll install it next time .
Old 08-24-2012, 03:32 AM
pdxrealtor's Avatar
Nice parts list and ya... Fun weekend ahead of you.
Start with something you know will be easy to conquer and get your momentum going for those busted mani bolts.
Not sure if you read my header post but I had a stud remover. Took two turns on the stud and it snapped a second time.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 08-24-2012, 04:09 AM
citiboy's Avatar
Thanks for the heads-up bro, i have all the tools that needed as i'm an auto technician by trade (master tech at honda). Yes, i saw your post on broken manifold bolts....hopefully mine wouldn't give me a hard fight.
One thing though, can you check your torsion bar support bracket bushings if it's welded to the frame....mine is and it's loose....it's kinda stupid move from gm though.....now, i have to drill holes to install the replacement parts.
Old 08-24-2012, 04:14 AM
pdxrealtor's Avatar
I'll check.... ASAP. What wasn't a stupid move by GM?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 08-24-2012, 04:17 AM
citiboy's Avatar
Thanks...LOL!
Old 08-24-2012, 04:45 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Those Moog Tie Rods don't look any beefier than OEM TR's.
If you do any amount of serious off-roading you might want to upgrade to something like <THESE>.
Tom, good to see you over here! Thanks for the reminder on the straps, I really need to get a pair of those. I've been lucky so far, been wheeling with the Cognito UCA's for quite a while now, but the ball joints don't seem to have suffered any.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 08-24-2012, 04:53 PM
tomp's Avatar
Good advice on the TRs Summit! Moog makes good stuff but those TRs look weak like OEM.
Even highway miles will wear those ball joints early without the straps. Of course mines a daily driver so I see the early failures more than most and Im running their uniballs.
Old 08-24-2012, 09:08 PM
citiboy's Avatar
Summit, i went with the Moog tie-rods because of one thing....these will act as a fusible links on the steering. If i install a stronger tie-rods, something will give down the line. It's easier to replace the tie-rods especially on the trails. Recently, i busted my RF inner half-shaft....luckily a friend of mine had a spare and i replaced it on the trail....imagine if the half-shaft didn't give, the next in-line is the diffirential. I replaced it with Cardone Select and i never had any problem yet.
Thanks for the suggestions though .
Old 08-24-2012, 10:46 PM
tomp's Avatar
If Summit adhered the the Fusable Link principal, he wouldnt last 5 minutes on the trails he wheels on. The H2 tie rods are severely under sized compared to the strength of the rest of the steering components. In fact, you can buy the strongest tie rods you can find an they will still be the first thing to give out. As far as the front diff goes, all of diffs I have heard of breaking had OEM shafts and I have yet to hear of an H2 front diff give out on the trail. Maybe some have & I haven't heard of it. All of the ones I have heard about have been on the street. The later model H2 front diffs 04+ have proven to Hold up very well. So well that I plan to install the Unbreakable RCV shafts. The reason the OEM and Cardone shafts break easily is because the outer metal housing is softer than the hardened ball bearings. This causes the bearing to peen the housing with small indentions over time. You never know what will cause them to break, might be something rediculous when they let go.
Old 08-24-2012, 11:55 PM
citiboy's Avatar
Well, got a 45min. spare time and installed rear shocks and stab links...only thing that bother me are the grease fitting on the links....hopefully rocks wont shear them.
Old 08-25-2012, 12:04 AM
citiboy's Avatar
tomp, thanks for the great info as always, for now, i'll see if this TR would hold for the type of trails we do here....i actually almost bought the DMAX rods.
We have one H2 front diff grenade on the trail and his oem half-shaft we're perfectly OK. Don't know how what happened though.
Old 08-25-2012, 01:04 AM
pdxrealtor's Avatar
I peeked under the truck and yes, my bushings are welded also.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 08-25-2012, 01:09 AM
citiboy's Avatar
Thanks bro...... while in there, did you checked if the bushings are loose? you might be surprise what you find.
Old 08-25-2012, 01:17 AM
pdxrealtor's Avatar
No, but I will. I was just taking a quick peek for ya.
How do you tell if they're loose?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
