09-28-2012, 03:17 PM
LED Side marker/turn signals... where to buy?
My H2 has been good to me. Other than a couple of worn suspension parts, I've only had to replace a broken window switch (I'm sure my daughters had something to do with that) and now a turn signal.
So, anyone know where to buy a stock replacement turn signal/side marker lamp for the front (yellow) without going to the dealer?
My cost at the dealer is 89 bucks. Obviously not going to break me but surely I can find one more reasonably priced.
Any suggestions? Anyone have any for sale that perhaps they swapped to smoked or something?
Thanks,
Mark
09-28-2012, 04:09 PM
Re: LED Side marker/turn signals... where to buy?
Originally Posted by guruerror
Thanks bud... guess I'll order it from the dealer. By the time GM partsdirect adds shipping, I'm back where I started.
GM
Part # Category Description Pack Qty Unit Price Quantity Total Qty Ordered Ext.
Price YOU
SAVE Core Charge TOTAL
*25952319 All LAMP 1 $69.91 1 $69.91 $44.33 $0.00 $69.91
Shipping & Processing & Handling:
$18.53
Your Total Charges: $88.44
Mark
09-29-2012, 05:53 PM
I havn't had any take a **** on me yet...but since you have some out- did you think about cracking them open and trying to replace the led?
09-29-2012, 06:26 PM
I've had one out for a year now, and I just passed inspection with it lol.
I think I'm just going to figure out how to cut it apart from the back side and either see where the circuit board it fried (as it comes and goes) or just remove the existing setup in it and find a harness for a small either single or double light setup that can be easily replaced.
Reseal with RTV and the works
10-10-2012, 12:55 AM
An update...
I ordered one and it came in. When I drove in that morning, it was out. When I started the truck up and pulled it into the shop, it worked.
Go figure.
I sent it back.
Mark
10-10-2012, 06:24 AM
Mine is doing the same thing ... maybe a bad connection?? I'm gonna mess with it when I get a chance
10-10-2012, 12:25 PM
I took it off and looked at it. The plug in the backside is a sealed unit so there isn't much to do with anything.
Not sure why it started to work but better than spending 100 bucks.
Mark
10-10-2012, 05:32 PM
you know that ****ers gonna crap back out on you now that you sent the replacement back.
10-10-2012, 06:53 PM
Mark
Yup ... they are sealed I replaced both fronts already to the tune of $80.00 + each
Both my fronts went out and never came back on so I thought the rear (coming on and off) may be a loose connection  Not sure why a bulb would start to work again so maybe a connection??
10-11-2012, 12:21 AM
My rear lower right brake light isn't flashing anymore  is that a relay issue?
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
10-11-2012, 02:04 AM
Try changing the relay ($10). All of my marker lights would turn off and on intermittently so I changed the relay. It hasn't happened again albeit its only been about 3 weeks since the relay change.
10-11-2012, 02:43 AM
Okay thanks for the help, I'll try that.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
10-15-2012, 05:51 PM
Do you have a part # for that relay? My right front started flickering 2 weeks ago and is out completely now. My passenger side front goes out and comes back on so I figure buy a set and change both at the same time. If this doesn't fix the problem I'll have to check connections extensively and also replace relay.2oo5/8yr old L E D's? What's the lifespan on these?
04-15-2014, 11:34 PM
I know this thread is old, but any one still around on the forum resolve their side markers blinking intermittently by replacing just the relay? I was just about to order new front and rear side marker assemblies before I found his old thread. Been having issues for years with the side markers on the passenger side.
\'05 H2 Lux Pewter SUV, Nav, Air, Sunroof, 22x10 E Forged EF16 with BFG Limited Edition Mud-Terrain T/A 335/55R22 and varies Chrome Parts
\'08 H2 Lux White SUT with Sedona interior - SOLD
\'08 H2 Lux White SUT with Sedona interior and 6'' Fabtech Lift
