10-03-2012, 01:57 AM
Limb Riser
I know some of you are running limb risers on their H2s
Post up some pics...I'm working on a custom setup, but could use some additional ideas.
CNTRY
DTOM
10-03-2012, 03:49 AM
Re: Limb Riser
I'm putting some on mine...long list. Look for the mackinaw island summer hummer trip threads. Bunch of guys had them, a lot of pics. They might be on one of the other sites, local section, great lakes/Midwest/Michigan.
10-03-2012, 09:40 PM
Re: Limb Riser
Here is a pic of mine. They have a stainless carabiner at the top end that feeds through a hole in the aluminum angle running along the roof crossbars. At the lower end, there is another stainless carabiner that runs through one eye of a turnbuckle. The other eye of the turnbuckle is attached via stainless carabiner to a u-bolt that's attached to the brushguard. When not in use, I loosen the turnbuckle, detach from top then bottom, roll 'em up and store in the front door pockets.
The aluminum rails up top are 1.25" x 1.25" x .25" and work great for taking the limbs off of the risers and letting them ride all the way to the back above the crossbars. They also work great as anchors for tying stuff to the roof and handles to grab when standing on the steps.
Mike
2000 HUMMER HMCS, kevlar flat black, Rubber Duck lift, Predator stage 3 kit, Predator (Wilwood) Big Brake kit, a work in progress...
2008 H2, graystone, air suspension (DELETED), U-steps, SMA brushguard w/valance (DRLs replaced by PIAA 520s), black taillight guards/locking fuel door/roof crossbars (x4), Cognito UCA/pitman-idler, Bilstein shocks, Rancho steering stabilizer, Kryptonite tie rods, green keys, Fuel D525 20" Revolver, 37" Nitto Ridge Grappler
10-05-2012, 02:37 AM
Re: Limb Riser
Interesting idea KT2T...
I'm working on fabbing some brackets that will attach to the roof rails and protrude past the windshield. Once I get them cut and powder coated I'll post up some pics.
CNTRY
DTOM
10-06-2012, 10:23 AM
Re: Limb Riser
I attached the Limb risers from the SS GOBI Stealth rack to my SS Manik Brush Guard/Push Bar. A picture is worth 1000 words so here is 3000 words!
Re: Limb Riser
10-06-2012, 10:25 AM
Re: Limb Riser
10-13-2012, 10:22 PM
Re: Limb Riser
Thanks to everyone who posted up pics...
I just finished mine this afternoon...my emphasis was on 'tool-free, quick connect/disconnect.' I found these wonderful little things at Home Depot in the plumbing section called 'clevis hangers' (used to hang pipe from the ceiling) that give you an excellent quick connect to the brush-guard.
Since my rack is 'ultra-stealth' and sets back further than some, I couldn't use the rack as a roof-mounting point, so I had some roof rail brackets fabbed out of 1/4" steel plates which I proceeded to mod until they fit my needs. Here's the pics!
Dimension of the brackets:
Put a little bend on the end:
A little paint, padding, and a spacer:
Mounted:
That wonderful 'clevis hanger' that I mentioned earlier:
Turnbuckle setup:
Roof bracket connection:
Finished product:
When not in use, the brackets can be loosened and slid back so the arms do not extend so far out from the windshield.
Again, thanks to everyone who posted up pics and ideas!
CNTRY
DTOM
10-15-2012, 04:14 PM
Re: Limb Riser
Looks great man!
11-19-2012, 01:11 AM
Re: Limb Riser
PM sent to you Guruerror.
11-19-2012, 01:40 AM
Re: Limb Riser
None received...
CNTRY
DTOM
11-19-2012, 02:00 AM
Re: Limb Riser
Not to sound ignorant but what is the purpose of the cables running from the rack to the brush guard?
11-19-2012, 02:02 AM
Re: Limb Riser
Basically, to lift limbs and branches up over the truck without having them smack into the windshield.
CNTRY
DTOM
11-19-2012, 04:18 PM
Re: Limb Riser
Originally Posted by guruerror
None received...
Tried again...Lol
11-21-2012, 07:56 AM
Re: Limb Riser
Super Heavy Duty Limb Risers ... more like "Tree Risers"!!
11-21-2012, 01:59 PM
Re: Limb Riser
LOL! I'll have to take another pic of how they turned out...I found the same style clevis hanger in stainless steel and replaced the bolt and wing nut with a yellow zinc lock pin.
Gonna test them out at Rausch Creek, PA the first weekend in Dec...
CNTRY
DTOM
