12-02-2012, 09:43 PM
Rear bumper turn/brake light
Anyone know the part number for the socket?
Is it available alone or do you need to purchase the whole wire assy?
12-03-2012, 12:19 AM
Re: Rear bumper turn/brake light
Gm sells the connectors , you don't need to replace socket,
12-03-2012, 04:12 AM
The contacts inside the socket are corroded...they are removable/replaceable?
12-03-2012, 03:38 PM
CNTRY
DTOM
12-08-2012, 03:55 AM
I found one at the local auto parts store.
Standard-S779 socket....$5.50
03-12-2013, 03:56 AM
I have searched the treads and I can not find where although it appears as if you need a metal bracket to hold the light in place when converting an earlier H2 model (03) with rear bumper lights of that found in an (05+). Can some who has converted theirs confirm that? Thanks
03-12-2013, 04:04 AM
CNTRY
DTOM
03-18-2013, 06:20 AM
Excellent. it looks as if the bracket connects to just one bolt when I look underneath, closest to the side panel. I assume that all it needs ... correct?
03-19-2013, 01:18 AM
Also my thread in the General H2 Discussion section is not generating any responses so maybe someone here could tell me how to wire it up. My connector has 3 wires (ground, major, and minor). My bulb is a 2 filament bulb. I read where I could "easily" tap into the hitch harness. What say you
03-19-2013, 08:10 PM
1998 Chev Z71
2007 Chev Trailblazer SS
03-23-2013, 08:21 PM
ah ...ok... can someone translate that diagram into english for me
My connector has 3 wires, one is a ground. one (major) would be for the running (parking light) wire. then the last wire (minor) would be for ???? do I hook it up to the brake light wire or the turn signal wire?  I mean I dont think I can hook it up to both turn and brake ... can I???
thanks for your help
04-02-2013, 03:26 AM
Issue resolved
04-02-2013, 06:04 PM
How'd you fix it?
2003 Black H2:
2006 Blue H2:
