Old 12-09-2012, 03:11 PM
smileynialley's Avatar
smileynialley smileynialley is offline
smileynialley is on a distinguished road
Default 3rd transfer case seal in a year!
I have a recurring leak coming from the transfer case. The seal to the prop shaft at the rear is wearing away stupidly fast and causing transmission fluid to leak everywhere.
When I put my foot on the gas pedal, before the car moves i get a clunk. The same clunk happens when i sharply take my foot off the gas too.
Could this be linked with the seal leaking?
Any help would be great,
thanks
Old 12-09-2012, 07:48 PM
Default Re: 3rd transfer case seal in a year!
done some digging on the web and found a suggestion that replacing the prop shaft with a longer version (part no 15207223) will cure the clunk problem. obviously the clunk isn't the problem, the worn seals are the problem. would this be helpful?
Old 12-10-2012, 02:31 PM
tomp's Avatar
tomp tomp is offline
The clunk is normal for GM trucks. A longer prop is not good idea as it has to move in/out due to suspension travel in rear. The prop is causing early seal failure because small rocks and dirt get trapped in there and wear grooves in prop shaft. Simply replace prop with new OEM shaft and seal and problem will be resolved.
Old 12-10-2012, 04:48 PM
ok cheers mate. I'll get myself a replacement prop (can only get 2nd hand over here so hopfully it will be ok). Would the bearing inside the transfer case need rpelacing?
Old 12-10-2012, 11:15 PM
tomp's Avatar
Might check with any local GM deal to determine part availability. The bearing should be fine and no need to replace it unless you remove it.
Old 12-11-2012, 05:46 PM
we dont have GM over here.
