Old 12-29-2012, 04:04 AM
jarek m's Avatar
jarek m jarek m is offline
jarek m is on a distinguished road
Default Front license plate mount.
It's going to serve three purposes:
One... It'll provide four point mounting/full backing plate for the numbers plate. Anyone that ever hit high water at any momentum can attest to the need of that kind of support.
Two... Quick snatch point. Over the years I've seen dozens of SUVs flooded because of the amount of time it takes to utilize submerged loops that require use of D shackles.
Three... Easy access to the front hitch reciver for winch tray. Winch tray makes sense for us since 98% of the time the truck is a shool bus.
Parts needed, old hitch and ball, little sheet metal, rebar.
Missing the times when things where made to last.
Old 01-03-2013, 02:33 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Default Re: Front license plate mount.
I'm not picking up what you're puttin down... More explanation or pics please?
Old 01-03-2013, 03:16 PM
jarek m's Avatar
Busy, busy, busy... I'll move it along today, promise!
Old 01-03-2013, 08:45 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
So I guess you'll be drilling the tongue on that ball mount to work with the H2's front receiver's vertical hitch pin arrangement (I assume you want the ball upright)? And unless you have the original H2 articulated hitch pin which drops in from the top you'll have to use soemthing like the Bully Locking Hitch Pin which is a PITA to access under the truck to work the key.
I went with the Gobi spring loaded flip-up front license plate holder. Makes for a neat solution, and mounting my winch cradle is quick and easy.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 01-03-2013, 11:16 PM
jarek m's Avatar
I like the Gobi piece, if mine looks horrific that's what I'll go with. For the pin I'll go to local Tractor Supply, they have a wall of that stuff to chose from.
Old 01-04-2013, 02:10 AM
jarek m's Avatar
Well I tried things up but looks like I'm going to have to wait for the grill to be done with paint and installed to check for clearance when opening the hood.
Old 01-04-2013, 04:08 PM
SummitUp's Avatar
The only hitch pin that will work from the top is the factory articulated (hinged) pin. A straight pin that would be long enough to go through the receiver from the top can't be inserted because of interference of the grill. The only pin that can be used from the bottom has to be a locking pin to keep it from falling out (you can't get to the top of the receiver to insert the clevis into the hitch pin).
You can still get one of the H2 Trailering Accessory Kits on eBay which includes the articulating hitch pin.
Or you can get just the articulated pin from GM Parts Direct; Part No. 15059236 ($36.78).
And yes, you'll probably find that you cant open the hood all the way with a ball mount hanging off the front receiver.
Old 01-08-2013, 05:02 AM
jarek m's Avatar
Since I have to wait with the front I redid the rear mount. After an accident body place trashed the bumper mount and permanently installed the plate behind the spare tire, making it impassible to take the spare off. Genius!
This one is going to go on the swing away passenger side, out of the way.
Old 01-10-2013, 05:32 AM
jarek m's Avatar
Drilled two holes in the tire carrier, instated pair of rivnuts and bolted the plate mount with couple 1/2" spacer washers behind it. This way dirt won't get trapped betwen. After shortning the light wire by a mile I was done.
Tomorrow back to the front one.
Old 01-16-2013, 04:49 PM
jarek m's Avatar
Well... I got it welded up but it's not looking to hot. Leaning more at Gobe now.
Old 01-16-2013, 05:08 PM
SummitUp's Avatar
Can you still open the hood all the way?
Old 01-16-2013, 06:05 PM
jarek m's Avatar
Last picture is with it up all the way, forcing the springs I can get it to about half an inch from the plate.
Old 01-16-2013, 06:13 PM
jarek m's Avatar
The end product would be POR15ed ball and hitch, but still... What you think?
Old 01-16-2013, 07:46 PM
guruerror's Avatar
IMO...good idea, but I think I'd just go with the Gobi. It's got a cleaner look.
CNTRY
DTOM
Old 01-17-2013, 06:24 AM
Crush'em's Avatar
Crush'em Crush'em is offline
Crush'em is on a distinguished road
I'll third the Gobi plate mount. Looks hella clean and very practical...
2007 Hummer H2 Yellow SUV
37"x13.5"x20" Toyo Open Country MT's, 20x10 Method Racing 301's, Fox 2.0 Performance Series Shocks, Truxx Level kit, color matched grill, (Almost) all chrome removed, Removeable U-steps, Factory All weather mats, Gobi flip-up front plate, Factory brush guard
