Old 01-27-2013, 09:17 PM
H2FAR's Avatar
H2FAR H2FAR is offline
H2FAR is on a distinguished road
Default HUMMER WONT CRANK..NEED HELP
Howdy
Hoping someone might have experienced similar and could give a little advise. A few months ago my 35000 mile H2 wouldn't crank with the key in the run position. All other electrical systems seem fine. A few hours later it worked just fine and no trouble for weeks. Then it became more frequent and by cycling the key several times rapidly I could get it to crank. When that little trick stopped working I had it towed to the dealership and they replaced the ignition switch. Second tow to dealer resulted in checking the connection to the fuse block, putting some dielectric grease on the connector($125.00). Third tow to dealer they turn the key and it starts...sorry. Fourth tow to dealer new starter. Fifth tow to dealer they discover that a dead cell in my battery is the culprit...I am told it is acting like a resistor and robbing the truck of power. Seems strange because everything in the truck lights up and works fine just no crank. Low and behold get home from dealer Friday and the truck has been dead in the driveway ever since. Whats left ? I hate the fact that this licensed GM dealer is throwing parts at it and making a fool out of me. Any help would be appreciated.
2005 H2 Lux Stealth Gray w/body color grill
2004 SL55 AMG
2005 SSR 6 speed
2009 R350 4matic
1999 Suburaban LT 2500 4wd SOLD
Old 01-28-2013, 02:51 PM
HummerMann's Avatar
Default Re: HUMMER WONT CRANK..NEED HELP
I had the same thing happen and they replaced the ignition switch. All was fine for two years and then it started happening again and I pulled the OnStar fuse as well as having them replace the ignition switch again. There's an old thread about the ignition switches going bad and the replacements not being any better until 2007. No problems since then.
Hummer, like nothing else
Old 01-28-2013, 02:53 PM
HummerJim's Avatar
I also pulled my OnStar fuse after two dead batteries.
Old 01-29-2013, 05:32 AM
jarek m's Avatar
jarek m jarek m is offline
jarek m is on a distinguished road
We need to put together a list and locations of all the grounds in those trucks.
Missing the times when things where made to last.
Old 01-29-2013, 07:31 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-29-2013, 07:34 AM
HUMTECH's Avatar
1998 Chev Z71
HUMTECH's Avatar
1998 Chev Z71
Old 01-29-2013, 07:35 AM
HUMTECH's Avatar
1998 Chev Z71
Old 01-29-2013, 07:36 AM
HUMTECH's Avatar
1998 Chev Z71
Old 01-29-2013, 07:37 AM
HUMTECH's Avatar
1998 Chev Z71
HUMTECH's Avatar
1998 Chev Z71
Old 01-29-2013, 07:38 AM
HUMTECH's Avatar
1998 Chev Z71
Old 01-29-2013, 07:39 AM
HUMTECH's Avatar
1998 Chev Z71
Old 01-29-2013, 07:40 AM
HUMTECH's Avatar
G320 (SUT)
1998 Chev Z71
Old 01-29-2013, 07:41 AM
HUMTECH's Avatar
1998 Chev Z71
Old 01-29-2013, 07:43 AM
HUMTECH's Avatar
G100
On the left front frame body mount
Power and Grounding Component Views
G102
At the left front side of the engine block
G103
At the top right rear of the engine
G104
At the top left rear of the engine
G106
At the right rear of the engine compartment on the forward dash panel
G200
On the left side of the I/P behind the left kick panel
G203
At the lower right side of the I/P behind the right kick panel
G300
On the left side body mount in front of the driver door
G302
At the left inner center B-pillar
G304
Under the front passenger seat carpet
G306
At the right inner center B-pillar
G310
At the left frame body mount under the left rear passenger door
G320 (SUT)
Left side of the midgate assembly near C300
G401
At the left rear frame body mount
G402 (ZM6)
Attached to the front of the air suspension mounting bracket
G403
At the right frame body mount near the right rear door
G405
At the right rear frame body mount
G410 (Except SUT)
On the right rear inner side body panel
1998 Chev Z71
Old 01-31-2013, 07:00 PM
H2FAR's Avatar
The H2 has now sat at the dealer all week and they dont have a clue. I am asking for a new ignition switch with fingers crossed. Let let you know how I make out. Will pull the onstar fuse when it gets home.
Thanks for the replies!
2004 SL55 AMG
2005 SSR 6 speed
2009 R350 4matic
Old 02-01-2013, 04:29 AM
pdxrealtor's Avatar
Great info Humtech!!!! Subscribed for the dreaded future.
OP- Is your battery going dead? Or other issues?
If bat going dead install the priority start module, problem band aided well!
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 02-12-2013, 06:26 PM
H2FAR's Avatar
No battery issues. I'm now leaning toward anti theft issue. If I cycle the lock and unlock on the key fob 10-15 times it starts at ramdom. The problem also seems to occur more often when the temp drops below freezing. Really wierd. A friend suggested having a remote start installed and bypass the system. Does anyone know if there is a seperate anti theft module or if it is built into the main computer?
2004 SL55 AMG
2005 SSR 6 speed
2009 R350 4matic
Old 02-12-2013, 11:25 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Every once in a while my H2 won't turnover. I have remote start so I tried that and still no start. It happened about 5x so far and every time I waited a few minutes and then it starts?
