03-25-2013, 04:07 PM
Re: Need Help! Hummer gone nuts!
Make sure your battery is fully charged, and disconnect the On Star (remove fuse "Info").
03-26-2013, 12:26 PM
I too have electrical gremlins in my 2006. The only aftermarket electrical item is a backup camera dealer installed when new that displays on the nav panel. I'll be driving along and the red OnStar light will come on, or the red neutral light under the 4 W drive buttons will come on (even though the buttons have been replaced), the lights come on during the day and the nav panel turns to night black, or I'll get in the Hummer and the clock has lost two hours, but it starts right up. Then once in a while the battery will go dead if it sits two days, so I just keep it on the battery tender in the garage now.
03-26-2013, 07:38 PM
2003 Black H2:
2006 Blue H2:
03-26-2013, 11:25 PM
Great pictures.
Hummer, like nothing else
03-30-2013, 06:02 AM
Am no expert but IMHO it may very well be a sensor wire that has come lose behind the dash as a result of the sudden shock when you bottomed out. It will cost you a couple of grand to locate it and reattach it. Basically your
03-30-2013, 07:35 AM
Well with the exception that the lights haven't come back since........ I'm no expert either but it fixed itself the old fashion way..... bang it out.
It most likely was a lose ground somewhere for the BCM or a powerblock, whatever it was it has taken a break.
So no........... I'm not.......
2003 Black H2:
2006 Blue H2:
