Old 06-27-2013, 03:05 PM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
Default Connector Help
Anyone know where I can get the connector that hooks these two up at?
It for the PIAA lights that came with my new h2
2008 Hummer H2 Lux Ed. Sedona Interior. XD Spys wrapped in 37x13.5 Toyo Mtsss.
Old 06-27-2013, 03:42 PM
fyr145's Avatar
fyr145 fyr145 is offline
Moderator
Default Re: Connector Help
When you say "these two" are you referring to the 2 white connectors and mating them to one another???? If that's the case just cut the connectors and match the wires to their counterparts on the opposite end.
On the other hand, (based on the pic provided) the connector is showing 4 openings that would lead me to believe that those were connected to some kind/type of relay (as shown below) so when you turned the switch on, the relay closed the circuit and the lights came on. Have you looked at the PIAA website or gave them a call to ask about their wiring??
Lastly, use a meter and test/check the wires to see what goes where.
Old 06-27-2013, 04:13 PM
ryaleon's Avatar
Yes, I was referring to the white connectors, but what you said about the relay makes lots more sense.
Old 06-27-2013, 06:31 PM
fyr145's Avatar
Moderator
the 4 connectors (if it is a relay connection) would work as follows:
one to the power the relay
one to ground the relay
one to the switch
one to the accessory (light)
Being that there are the 4 outlets and how they are arranged/configured (all horizontal & side by side), leads me to believe its a relay connector. The other "clue" is that its square and PIAA has a square relay unit.
Old 06-27-2013, 07:18 PM
ryaleon's Avatar
It is indeed a relay that is missing. Confirmed by PIAA
Old 06-27-2013, 10:44 PM
fyr145's Avatar
Moderator
Mystery solved...............glad I was able to help!
Old 06-28-2013, 01:20 AM
ryaleon's Avatar
I appreciate it
