Old 09-07-2013, 10:01 AM
New York City's Avatar
New York City New York City is offline
New York City is on a distinguished road
Default Some Help Please. (transmission - oil pressure)
Ok let me start by saying.
I had my transmission start slipping on me.
I got it rebuilt with a new torque converter.
But before when it was slipping, my oil gauge would jump to 80 and back to the middle when I would accelerate.
I thought it would be fixed once the transmission was rebuilt.
Well it is still the same. When I accelerate the oil gauge on my dash jumps towards 80 and then back to the middle when I stop accelerating.
My questions are:
What may be the problem? (Is it the oil pressure sensor that went bad when I would accelerate my hummer and force the gear to kick in when my tranny was slipping?)
How urgent do I need to change the oil pressure sensor if so? (Damage outcome if I wait?)
Now my h2 is having slipping issues again. I had a check engine code come on for a solenoid. The tranny place has ordered it and will be installing it as soon as I come in. (the car is driveable, just has a slight slip when going in 3rd gear. Drives good after that) But this is the second time in 1 month the solenoid is going to get replaced. Any clue what is going wrong?
Also, what tranny fluid should have went into the tranny?
(I'm asking to make sure they put the right one)
Old 09-07-2013, 12:03 PM
jsbihn jsbihn is offline
Moderator
Default Re: Some Help Please. (transmission - oil pressure)
i work on cars like i have always worked on people.... with this motto. if you hear hoof beats, think horses not zebras. meaning, think or do the most simplest first. in this case, i am not sure who did your diagnosis for you but either way i would have started with the most simplest.
usually it is the oil (usually the level or the type), so I would have replaced or checked and filled the oil for the trans. but I would assume that everything was replaced and refilled correctly after you had the trans replaced.... at least we hope.
first i would check the oil level. it just might not have enough oil in it. add some if needed and see if that fixes it. just because a "professional" might have done your swap, doesnt mean it was done right.
even if still, it wouldnt hurt to try changing the oil.
the tranny remanufacturer might recommend a different oil from stock. maybe something a little thicker or maybe thinner. some trannys also might need a break in oil. depends on what your transmission guy does and what he tells you to do.
but based on what you are telling us and the common problem between both transmission....
I would say that the main culprit probably all along.... even before the tranny was replaced.... was the trans oil line or pump.
if the line is blocked, you will not have proper circulation of oil. if the pump fails, then of course the trans oil level will not be correct and there wont be enough oil in the trans to shift correctly. and of course if it is acting like this across two transmissions i would say this is probably more likely.
if you arent getting any CEL lights, could just mean a bad sensor or not.
i have found out that unlike my Vette, these trucks have alot of things not covered under their sensors. My vette has so many sensors and they are all running in sync that if a sensor goes off in the drivers seat (yep there are sensors for the power seats too) it would put the car into "limp mode" or shut it down. Not so much in the H2. I have some minor issues with my H2 and yet no CEL and no codes are registering off my code reader
Anyways.... I hope this helps
'03 H2 (name: Big Gulp)
