10-20-2013, 03:25 PM
Re: WTH...Smelling gas/Fuel pump went out
I just had to replace my fuel pump because of this issue. The pump didn't fail but the lock ring holding the pump in place rusted out completely. It was so bad that on a full tank gas would spew out the top of the gas tank. Had rust and all types of other sediments in the tank. I had to drain all fuel, wipe the tank clean and refill once the new pump was in place. It was nasty!
2007 H3 "Tactical Edition" - Black
Gobi Stealth Rack & Ladder
TrueFlow Intake w/ inlet upgrade
Borla Catback Exhaust
PCMforless Tuned
Bilstein Front & Rear Shocks
Hellwig Rear Anti-Sway Bar
35" Toyo Open Country MT's
____________________________
2005 H2 SUT - Military Green
K&N FIPK Intake
Gibson SS Extreme Exhaust
Predator 87 Octane Tune
20" XD Strike 807 Wheels
10-20-2013, 05:29 PM
I wonder why so much rust? Winter road salt maybe?
BUNNY15 aka Tiffany
2003 H2, Moog Idler, Pitman, Up/Low BJ, In/Out TR, Fabtech 6in Lift, Yokohama Geolander M/T 40x15.50x20, Black XD Bombs 20x9, Bilstein 5100 Shocks, Yukon 5:13 gears f/r, Hypertech Max programmer, KC 851 HID's 35w, Pioneer DVD/NAV/TOUCHSC, 10" woofers, 6k Headlight HID's, White LED DRL (wired to run w/headlights on),Custom University of Texas gauges, Custom yellow paint. interior, Fuel pump/filter (Feb '13), Rebuilt 4L60E (April '13) & Rebuilt Transfer Case (Oct '14)
10-20-2013, 05:32 PM
It's the way the tank is designed... It's inevitable that debris, salt, dirt etc. will get on top of the tank and be trapped there. It leads to tons of corrosion around the pump which is a metal top.
When you replace the pump go with the Delphi model as it has a hard plastic topping to the fuel pump. I had an evap leak P0455 code for about a year until I took the tank down and discovered a leak around the seal.
PCMforless Tuned
K&N FIPK Intake
10-23-2013, 05:25 PM
Gotcha!
BUNNY15 aka Tiffany
