Old 11-16-2013, 09:20 PM
smileynialley's Avatar
smileynialley smileynialley is offline
smileynialley is on a distinguished road
Default Lights dim when electrics used.
Basically, I've noticed the headlights dim whenever I press the brake pedal.
This kept happening and tonight I noticed the lights would dim when I used the windows.
Then, when I pressed the "all four windows up" button, the lights would pretty much turn off and all my electrics inside the Hummer cut out momentarily. The engine stayed on and all was fine when I turned it off and on again.
The only thing different I've noticed is a high pitched whirring / wining noise coming from the dash board area, which seems to speed up and slow down with the revs.(not sure if these are linked)
Any ideas guys? i'm stumped!
Thought it could be the alternator but the gremlins don't match that problem.
Old 11-17-2013, 03:34 AM
fyr145's Avatar
fyr145 fyr145 is offline
Moderator
Default Re: Lights dim when electrics used.
Could be any number of issues. Lets look at a few of these.
1. Voltage regulator: Most late model units today have the voltage regulator built inside the alternator. To rule this out, you could simply get one of those load testers and a meter and measure the output of the alternator. While your at it, check the tension of the serpentine belt to make sure that you're getting the proper revolutions to even generate any power. Maybe also look at the pulley on the alternator and ensure that its not worn out and making any noises. You can find out how to make certain connections for specific tests on You Tube.
2 Battery: You could have a bad cell in the battery. How old is your battery? (Here in AZ, batteries only last an average of 3-4 years due to the excessive heat.) But large electrical loads from powerful aftermarket audio equipment or using lots of off road lights can also drain a battery. If the battery is not taking a charge, then either the alternator is not sufficiently charging the battery OR the battery is not taking the charge provided by the alternator.
3. Bad or loose Ground(s): Another remote possibility is a ground wire is not secure to the frame. Check all ground locations starting with the engine, then the negative cable on the battery, and so on.
These issues is where I would start to begin to rule systems out. As with any electrical gremlins.......its always best to start with one system at a time and go from the easiest to check to the more difficult ones. Be systematic in your approach.
Old 11-18-2013, 09:10 AM
Mister Peebody's Avatar
Mister Peebody Mister Peebody is offline
Mister Peebody is on a distinguished road
My vote is with #3! Corroded grounds will cause all sorts of strange issues.
2005 Stealth Grey H2 Luxury - Billet and Carbon Interior, Custom Audio/Video, 22" Zinik wheels with 35" Nitto Trail Grappler M/T tires, HID headlights
Old 11-18-2013, 12:12 PM
thanks for the replies,
I have had a look around the engine bay and there is nothing obviously loose or corroded etc.
It seems like the alternator can't produce enough power to power everything in the car so when you use the windows or brake lights etc, the headlights and cabin lights either dim or cut out altogether and the stero cuts out.
No affect on the engine though.
Old 11-18-2013, 04:29 PM
fyr145's Avatar
Moderator
Ok then, if you have ruled out #3, then the next thing I would check is the battery then the alternator.
As I stated earlier, get a load tester or you can go to an AutoZone, O'rileys, checker, etc. and have them put their unit on the battery and check it. The load tester simulates having various electrical loads being placed on the battery by them flipping a switch or turning a dial depending on the type of tester then seeing if the battery can still maintain proper output even with a big load draw.
The other test is to check that alternator. just because you see the serpentine belt going around and spinning the pulley on the alternator doesn't necessarily mean that its putting out a charge to the battery. As stated earlier as well, most late model alternators are now built inside the alternator. (I upgraded my stock alternator from the factory 145 amp to a 200 amp because I had added the factory brush AND roof lights.) In the old days, the regulator was a separate unit and if it went faulty or bad, you could simply change out the regulator. Not any more.
The only other issues that I can think of if its still doing it after completing the previous steps mentioned above, is to go on a search for any power wires or connections to your accessories that may be touching or possibly arching on the body. Or worn insulation from being pinched or rubbing on something from vibration. Typically, when these issues occur, it would cause a short and blow the fuse.
Sometimes people tie all their accessories into one power power outlet or line. When all these are being used, the outlet cannot support all of them simultaneously thus causing a voltage drop.
Keep us posted on how the battery and alternator testing goes.
Old 11-18-2013, 05:04 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
There should be other frame (chassis) grounds also not just what is obvious in the engine compartment.
Old 11-18-2013, 06:46 PM
fyr145's Avatar
Moderator
Thats true...............I forgot to mention that.
stupid me........ my bad.
Thanks LoJac
Old 11-18-2013, 08:03 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
One other thing, still related to testing alternator. May be putting out but if one diode in alternator fails then it will only put out 2/3 of its regulated output, 2 diodes out 1/3 charge. Something to keep in mind when testing alternator output.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 11-19-2013, 11:11 AM
The battery was replaced last year. It starts first time no issues so the battery is good.
I thought it could be a bad earth/ground too but the lights dim when the windows are activated too. Does anyone know if the windows and the brake lights happen to share an earth?
I also mentioned that I've noticed a whirring noise coming from the front of the car which gets faster as the revs go up, I'm wondering if this is an alternator problem.
Old 11-19-2013, 02:20 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
As the others mentioned... it sounds like the culprit is likely the altenator, have it tested.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 11-19-2013, 03:32 PM
iwillnc's Avatar
iwillnc iwillnc is offline
iwillnc is on a distinguished road
Mine also dims with something as simple as windows being rolled up/down, doesn't really affect anything so I've just ignored it.
Old 11-19-2013, 07:12 PM
LoJac963's Avatar
Mine has done that for a while also especially with rolling up all the windows at the same time. I'm sure the alternators are the issue but I still have normal volt output so I'm not concerned about it right now.
FYR where did you pick up your higher output alternator?
Old 11-19-2013, 08:03 PM
HUMTECH's Avatar
You can have poor alternator output with good voltage readings. Its the lack of amperage which can cause issues
1998 Chev Z71
Old 11-20-2013, 12:28 AM
fyr145's Avatar
Moderator
American made. New not refurbished. California based. 100% reputation report. warranty. Free expedited shipping.
http://www.ebay.com/itm/HIGH-OUTPUT-ALTERNATOR-CADILLAC-BUICK-HUMMER-SAAB-200AMP-ONE-YEAR-WARRANTY-/300990826344?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2007|Model%3AH2&hash=item4614738768&v xp=mtr
Old 11-20-2013, 10:43 AM
LoJac963's Avatar
Wow that's not a bad price! I may consider one of those with all the lights I have installed on the rack and elsewhere.
Old 11-20-2013, 03:52 PM
fyr145's Avatar
Moderator
True!!.......Even with all the lights you do have on yours, you could even go to a 250 amp. I stayed with the 200 amp because I wasn't running as many lights as you have. It seems to be fine so far with no issues. Install was a breeze!!
All I did was get the part number of my stock alternator and made sure that the new one that I was going to get was a direct plug n play replacement with my part number. Their site provided this info and combined with the other factors that I listed earlier, I decided to get it.
Old 11-20-2013, 11:37 PM
LoJac963's Avatar
Funny you mention that. I was making my rounds on Ebay looking for any deals and actually found a new 250amp alternator for $179. Definitely something I'm going to look into at some point.
