Old 06-21-2005, 12:52 PM
Durite Durite is offline
Durite is off the scale
Hi there, I Own a Hummer H2 and the other day i went out to it and the battery was flat. i charged it back up and now you can still hear the fan inside running even with the keys out of the ignition. any ideas?
Old 06-21-2005, 07:28 PM
DRTYF? (the imposter) DRTYF? (the imposter) is offline
DRTYF? (the imposter) is off the scale
Take it to the dealer. What else are you gonna do? You could always trying smacking the console like an old television. lol
Old 06-22-2005, 03:16 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
A direct short to ground on the blower motor circuit. This could be caused by a leaking battery corroding wires under the hood, a common ACDelco battery issue.
Old 06-22-2005, 03:21 PM
NoMoGMPG's Avatar
Pay no attention to this post, it isn't DRTYFN, it is someone named "CheeseDick" hacking and trying to start trouble. DRTYFN would insult you much more eloquently.
Old 06-23-2005, 05:55 AM
Cheers, Do you know where abouts its likely to be, or possibly have a picture of all the wires?
Old 06-23-2005, 08:53 AM
Jimstepside Jimstepside is offline
Jimstepside is off the scale
Its probably the blower motor module thats in the heater case.
2003 Pewter, SunRoof, Nav, AirHorns, 6 disc in-dash cd changer, B/U camera, ipod
Old 06-23-2005, 01:02 PM
Is there anyway of checking if it is that?
Old 06-23-2005, 07:46 PM
you would need a volt meter and a wiring diagram. The part only takes about a half hour or so to replace, so I would just take it to the dealer. I work at a gmc dealer and have replaced a few of them on yukons for the same condition. I dont know for sure if the hummer is same but i would think that it is. I never looked at mine to see.
Old 06-23-2005, 07:53 PM
If you take down the right hush panel under the dash, you should see the blower case and the blower motor. There should also be a piece in the case with I believe with 2 harnesses coming out of it and 1 of them goes to the blower motor. Unplug it and the motor should stop.
