Old 07-10-2009, 04:12 AM
numberoneolddiver numberoneolddiver is offline
numberoneolddiver is on a distinguished road
Default grease fittings location
threr was a posting some time ago about the number and location of all the grease zerks. I had my h2 in for servicing and they only found 6 fittings this is a 2005 hummer any suggestions,are there more than this?
Old 08-26-2009, 11:19 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Default Re: grease fittings location
here is the link
http://www.elcovaforums.com/forums/s...ad.php?t=30787
Old 08-27-2009, 01:51 AM
Easy Ed Easy Ed is offline
I'll try to post all eleven of them in larger pics versus the old one I did. Hope it helps better before.
Ed
Attachment 51403
Attachment 51404
Attachment 51405
Attachment 51406
Attachment 51407
Attachment 51408
Attachment 51409
Attachment 51410
Attachment 51411
Attachment 51412
Attachment 51413
Old 09-01-2009, 12:36 AM
lvmyhmr lvmyhmr is offline
lvmyhmr is off the scale
Great pictures! Just goes to show you you can not trust a grease monkey! My H2 has 90K on it and the upper idler (the one in the mirror in your pic) had never been greased. It was replaced at 50K under warranty. I changed it to a 90 degree zerk and am greasing it myself from now on. They have to take the skid pan off to get at this one and that is how they stripped the threads out of the frame with their air gun! The torque on the UCP is only 22 ftlbs according to the service manual.......that is not an impact gun torque.
Thanks for posting again. Bet I am not the only guy in this position!
Old 04-06-2015, 02:06 PM
Humvee21 Humvee21 is offline
Humvee21 is on a distinguished road
Excellent thread. I just got to these this weekend, but I wasn't able to figure out how on earth one can get to the one on the upper idler arm. I guess you have to unbolt it to access it? Will change it to a 90 deg zerk then.
Old 04-07-2015, 12:24 AM
These were to be changed out to 90 degree ones by the dealership on the early models when they came in for lube and oil change. I just went ahead and did it myself by un-bolting it and putting a 45 degree in (seen in the picture) since I was doing all my own work on ours.
Good luck, Ed
Old 04-07-2015, 03:54 AM
Good luck, Ed
Interesting. The H2 was serviced by the dealership since new up until about 60k miles. I'm not surprised they didn't change it. I haven't had a good dealership experience yet.
Do you remember the thread size for the replacement? I'm guessing 1/4"? Thanks!
Old 04-07-2015, 11:21 AM
Looked in the garage "automotive junk drawer" (I never throw anything away that I think I may need) and did find a straight out zerk that has a tapered 1/4-28 thread. I would say that would be the correct size.
Good luck, Ed
EDIT: Would need H-109-A
http://www.saeproducts.com/taper-thr...-fittings.html
Old 04-07-2015, 01:21 PM
Good luck, Ed
Thanks Ed!
Old 04-08-2015, 12:31 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
The idler arm on the HUMMER H2 has a grease fitting near the top end of the shaft facing the right-hand frame rail. Access to this fitting is very limited and may be accomplished, although not easily, with the use of a 90? grease gun adapter. However, to assure an adequate lubrication at each maintenance interval, it is recommended that the grease fitting be replaced with a 90? style fitting, P/N 09417903, pointing upward.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 04-08-2015, 12:33 AM
HUMTECH's Avatar
That's the gm bulletin, not a mandatory replacement but a recommended one. I do believe if my memory serves that it was a customer pay item as well.
1998 Chev Z71
Old 04-08-2015, 12:46 AM
oops, my bad ;-) Thanks HUMTECH
Old 04-08-2015, 01:41 PM
Thanks ya'll. I was able to find the TSB. Seems like the GM P/N for the grease fitting is no longer available or the ones that I have found with that P/N are $30 and above. Not paying that price for a grease fitting. I ordered the one Ed posted above.
Old 04-09-2015, 06:53 PM
Got the grease fitting today. Would ya'll recommend any loctite on the threads? Should I be worried that the fitting won't be sealed?
Old 04-09-2015, 07:55 PM
HUMTECH's Avatar
No Loctite, jst screw it in snug they can break easy if over tightened, it wont need to be sealed just snug it up
1998 Chev Z71
Old 04-25-2015, 06:51 PM
pdxrealtor's Avatar
If you replace your idler arm get a MOOG and it will come with a nice extension tube you can zip tie right up front for nice easy access with your grease gun.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
