07-09-2003, 12:34 AM
Document ID# 1337786
2003 HUMMER H2
Air Conditioning (A/C) Inoperative/Intermittent, A/C Blows Warm Air (Replace A/C Low Pressure Cycling Switch) #03-01-39-007 - (05/29/2003)
2003 Cadillac Escalade, Escalade EXT, Escalade ESV
2002-2003 Chevrolet TrailBlazer, TrailBlazer EXT
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2002-2003 GMC Envoy, Envoy XL
2003 GMC Sierra, Yukon, Yukon XL
2002-2003 Oldsmobile Bravada
2003 HUMMER H2
Condition
Some customers may comment that the A/C system is intermittently inoperative or blows warm air.
Cause
An intermittent inoperative (open) A/C low pressure cycling switch may be the cause. This is an intermittent condition and temperatures may play a critical role if the vehicle is in the failed mode or operating as designed.
Correction
Follow the diagnosis and service procedure below to correct this condition.
Park the vehicle inside or in the shade.
Open the windows in order to ventilate the interior of the vehicle.
If the A/C system was operating, allow the A/C system to equalize.
Turn OFF the ignition.
Open the hood and install fender covers.
Caution
Avoid breathing the A/C Refrigerant 134a (R-134a) and the lubricant vapor or the mist. Exposure may irritate the eyes, nose, and throat. Work in a well ventilated area. In order to remove R-134a from the A/C system, use service equipment that is certified to meet the requirements of SAE J 2210 (R-134a recycling equipment). If an accidental system discharge occurs, ventilate the work area before continuing service. Additional health and safety information may be obtained from the refrigerant and lubricant manufacturers.
For personal protection, goggles and gloves should be worn and a clean cloth wrapped around fittings, valves, and connections when doing work that includes opening the refrigerant system. If R-134a comes in contact with any part of the body severe frostbite and personal injury can result. The exposed area should be flushed immediately with cold water and prompt medical help should be obtained.
Notice
R-134a is the only approved refrigerant for use in this vehicle. The use of any other refrigerant may result in poor system performance or component failure.
To avoid system damage use only R-134a dedicated tools when servicing the A/C system.
Use only Polyalkylene Glycol Synthetic Refrigerant Oil (PAG) for internal circulation through the R-134a A/C system and only 525 viscosity mineral oil on fitting threads and O-rings. If lubricants other than those specified are used, compressor failure and/or fitting seizure may result.
R-12 refrigerant and R-134a refrigerant must never be mixed, even in the smallest of amounts, as they are incompatible with each other. If the refrigerants are mixed, compressor failure is likely to occur. Refer to the manufacturer instructions included with the service equipment before servicing.
Install the J 43600 ACR 2000 Air Conditioning Service Center.
Important
The ambient temperature must be at least 16°C (60°F) .
Do not induce additional air flow across the front of the vehicle during the test.
Record the ambient temperature displayed on the J 43600.
Record readings of the low and high side STATIC pressures. The pressures should be within the specifications listed below.
Above 16°C (60°F): 345 kPa (50 psi)
Above 24°C (75°F): 483 kPa (70 psi)
Above 33°C (90°F): 690 kPa (100 psi)
If the static pressures are within specification, continue with Step 12.
If the static pressures are NOT within specifications, refer to Leak Testing (SI Document ID# 1141201).
Apply the parking brake.
Place the transaxle/transmission in PARK.
Start the engine.
Turn on the A/C system.
Inspect the A/C compressor to see if it is operating properly.
If the compressor is not operating as designed, tap on the low pressure cycling switch (2) with a small hand tool. The compressor should start operating correctly.
If the compressor does not operate correctly after tapping on the low pressure cycling switch (2), disconnect the switch and jumper the lower pressure cycling switch connector with a fused jumper. If the compressor still does not operate properly, refer to HVAC Compressor Clutch Does Not Engage diagnostic in SI.
Important
DO NOT USE A/C low pressure cycling switch, P/N 15035084 on the vehicles listed above.
If the compressor does operate correctly after tapping on the switch or jumping the low pressure cycling switch connector, replace the low pressure cycling switch (2), P/N 89040362. Refer to Air Conditioning (A/C) Low Pressure Switch Replacement in SI.
Perform the Air Conditioning (A/C) System Performance Test in SI.
Disconnect the J 43600 ACR 2000 Air Conditioning Service Center.
Remove the fender covers and close the hood.
Parts Information
Important
Only a small quantity of parts are available. Please DO NOT order for stock only.
Part Number
Description
Qty
89040362
Switch, Pressure Cycling
1
Parts are currently available from GMSPO.
Warranty Information
Labor Operation
Description
Labor Time
D1180
Switch, Pressure Cycling - Replace
Use published labor operation time
Add
Diagnosis Time
0.0-0.3 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2003 HUMMER H2
2003 HUMMER H2
2003 HUMMER H2
Condition
Cause
Correction
Caution
Notice
Important
Start the engine.
Important
Parts Information
Important
Part Number
Description
Qty
89040362
1
Labor Operation
Description
Labor Time
D1180
Add
Diagnosis Time
0.0-0.3 hr
2003 HUMMER H2
09-08-2003, 12:18 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Klaus:
2003 HUMMER H2
Blah, blah, blah.
Blah, blah, blah.
2003 HUMMER H2<HR></BLOCKQUOTE>
1. What are fender covers?
2. RECIRC mode does not filter out nasty diesel fumes from cars in front totally as well as my other and previous cars (JEEP GC) did.
Anyone has same problem and/or knows most likely cause of this and/or possible solution(s)?
Thanks.
09-08-2003, 03:13 PM
The rubber mats that cover the paint finished surfaces of fenders so while working on vehicles the don't damage them and keep the grease or oil off too.
I don't know why they put covers on H2 since hood opens other way but better safe than sorry.
98 ZR-2 Blazer
Ex H2&3 owner
