Old 09-09-2005, 12:18 PM
Timster Timster is offline
Timster is off the scale
I read in an earlier post that there was a mirror problem on late model H2's. Last night I tried to fold in the mirrors using the mirror button. Only the left mirror folded in. I read the manual and it states how to rest the mirrors. I tried several times.
I even reset the right mirror manual. Making sure it was locked into position. But the right mirror never moved when using the auto fold button.
So here's the dumb question:
Aren't both mirrors supposed to fold in electronically? Or is time for a visit to the dealer?
Thanks,
Tim
2005 White Hummer H2 Adventure, Tinted Windows, Hella Fog Lights, Piaa Driving Lights, Chrome Fuel Door, V1, Gobi Rack W/ Ladder and Chrome Steps.
Thanks,
Tim
Old 09-09-2005, 12:44 PM
Yes, as I understand, both mirrors are supposed to fold in electronically. What year do you have? I know they are starting to put the '06 mirrors on '03-'05 models with mirror problems. Sounds like time for a visit to me.
Old 09-09-2005, 01:08 PM
Frank2005's Avatar
Frank2005 Frank2005 is offline
Frank2005 is off the scale
On my 05 SUT, both mirrors fold in at the same time.
2005 H2 SUT Lux *sold*
Old 09-09-2005, 01:49 PM
I have a 2005 H2 Adventure.
Looks like I need to take a trip to the Dealer.
Anybody have any experience with Los Gatos Hummer?
Tim
Old 09-09-2005, 01:50 PM
VTSTOMPER is off the scale
Looks like you get some new 2006 mirrors!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-09-2005, 01:51 PM
Looks like you get some new 2006 mirrors! </div></BLOCKQUOTE>
Hope they don't just give you one
Old 09-09-2005, 02:29 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">quote:
Hope they don't just give you one </div></BLOCKQUOTE>
I was thinking the same thing!
Old 09-09-2005, 02:43 PM
Zing's Avatar
Zing Zing is offline
Zing is off the scale
I had the same problem on my 04. Dealer said the motor on one mirror needed replacing.
H2 '04 Black
Old 09-09-2005, 06:07 PM
McHummer's Avatar
McHummer McHummer is offline
McHummer is off the scale
It happened to me... time to take it to the dealer.
Old 09-09-2005, 06:55 PM
Hummertech is off the scale
06 mirrors are not readily available yet, so you may get the same mirror that you have now.
Old 09-09-2005, 08:42 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Zing:
I had the same problem on my 04. Dealer said the motor on one mirror needed replacing. </div></BLOCKQUOTE>Hey Buddy!
Cycle the mirror three times. If that doesn't work, manually fold the offending mirror a couple of times and repeat. Worked for me and I haven't had a problem since.
Old 09-09-2005, 09:34 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Humm This:
What do you mean by "Cycle the mirror 3 times?" </div></BLOCKQUOTE>
Uh ohhh....
Old 09-09-2005, 09:41 PM
<span class="ev_code_RED">RED RUM !!!</span>
Old 09-10-2005, 12:59 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Hey Buddy!
Cycle the mirror three times. If that doesn't work, manually fold the offending mirror a couple of times and repeat. Worked for me and I haven't had a problem since. </div></BLOCKQUOTE>
I read the manual and did exactly that, about 4 times and it didn't work.
I also noticed when I had the window down and put the H2 into reverse the mirror growls but doesn't tilt much. I think the motors bad.
Thanks for the info,
Tim
Old 09-10-2005, 03:25 AM
What do you mean by "Cycle the mirror 3 times?" </div></BLOCKQUOTE>Press the button to cycle the mirrors in and out three times. Note: If both mirrors aren't working, guess at the duration to hold the button down. Then reverse it.
Timster, STOP! You need to read the next line of the OM. If you cycle the mirrors 5 times, they fall off.
Old 09-10-2005, 01:14 PM
Dan Dan is offline
What happens after the left mirror is folded and you hit the fold button again?
I think there is a way to set them so they cycle individually.
Old 09-10-2005, 01:28 PM
Oh wow. I didn't know that...I will have to look into that.
I know you can do that with curb view...
Old 09-12-2005, 06:03 PM
Dan Dan is offline
I found what I posted last year:
Here's how to turn the separate folding feature ON. Not sure how to turn it off though.
With all doors closed turn on the ignition.
Hold the fold button down. After BOTH mirrors have folded continue holding down until you hear 2 beeps
Turn the ignition off and then back on again.
Now, when you hit the fold button briefly it will fold the drivers side first, hold for 3 seconds and then the right side will fold.
To have the driver's side open and passenger closed continue holding and drivers will open then passengers now in sequence.
