04-19-2006, 04:08 AM
so i got my oil change before the reminder came on. and today i get the change oil message.
is there a way to reset this myself? its annoying to always hit the reset button everytime i start the car to remove the message.
thanks,
04-19-2006, 04:37 AM
I think you will need to call OnStar hotline and have it updated, i was talking to the a week ago and mention about the oil change reminder thingy..
Sup. Blu H3/DvD Navigation+DvD Changer/Rear CCD IR Camera/ SplashGuard, LocKing Billet gas cap, 4" Step Nerf Bars/Underbody lightning, and adding..
04-19-2006, 04:38 AM
by the way, how many mileage do you have before the reminder went off??
04-19-2006, 05:45 AM
dealer told me that my first oil change was at 7K. Changed oil when i hit 7K.
i now have 11K+ and the change oil reminder came on.
04-19-2006, 07:48 AM
Instructions are in the owner's manual.
How to Reset the Engine Oil Life System
The Engine Oil Life System calculates when to change your engine oil and filter based on vehicle use. Anytime your oil is changed, reset the system so it can calculate when the next oil change is required. If a situation occurs
where you change your oil prior to a CHANGE OIL
message being turned on, reset the system.
To reset the Engine Oil Life system, do the following:
1. With the engine off, turn the ignition to ON.
2. Press and release the stem in the lower center of the instrument cluster until the OIL LIFE message is displayed.
3. Once the alternating OIL LIFE and RESET
messages appear, press and hold the stem until
several beeps sound. This confirms that the oil life system has been reset.
4. Turn the key to LOCK.
If the CHANGE OIL message comes back on when you
start your vehicle, the engine oil life system has not reset. Repeat the procedure. See DIC Warnings and Messages on page 3-44.
04-19-2006, 03:43 PM
thanks f5...
normally these reset things arent on the manual hence why I didnt look.
thanks again!!!
04-19-2006, 03:54 PM
That's almost exactly how mine was. I got my first change around 6500. I have just under 12K miles now, and the light just came on about a week ago. I figured with the long trip this weekend I might as well get it changed.
04-19-2006, 11:20 PM
I've got 1400 miles on mine right now. I figure I'll switch to synthetic at about 5k miles. I'll use either Mobil 1 or Royal Purple.
2006 H3 - Luxury - Superior Blue - Sunroof - Chrome Pkg. - Chrome Step Tubes - AVN30D with rear view camera and iPod connection - Volant CAI - MagnaFlow dual exhaust - Throttle Body Spacer - Train Air Horn (to be installed) - More adds to come (New shoes & supercharger!)
1990 Porsche C2 (911) - Highly modified and very, very fast!
04-21-2006, 01:06 AM
Danm! that's a lot of info...vehicle now days are too technical..lol
I haven't got my oil change yet 1820 miles
OnStar gives me all the info almost everything computerized that is attach to my H3..pretty much im depending on them.
04-23-2006, 03:50 PM
Hey Fstop... I just changed my oil and followed the directions for resetting the oil change reminder that is in the manual (And above). I did NOT hear any series of beeps. I tried doing it several times and heard nothing. Does this reset the computer ONLY when the oil change reminder comes up? I only had 2000 miles on mine when I changed to Mobil 1 so the reminder hadn't come up. Will resetting it now change the reminder timing?
04-23-2006, 05:16 PM
I'd like to know that as well, as I am planning to change oil soon, and no oil change reminder light yet. If I do the above mentioned procedure, will it reset the reminder timing?
I read somewhere in forums that it's possible to reset in a bit different manner: you just turn the key in the ignition to ON position, but do not start the engine, and three times press the gas pedal within 5 seconds.
Thanks,
Vitaliy.
04-26-2006, 04:13 AM
The same thing happened on my white one, but after 3 resets it worked (got beeps every time), the black one is still at 62% oil life @ ~3500 miles.
Wondering if this is a trend????
2006 White H3, Adventure package, stock for now, 2006 Black H3 Adventure package with a few extras.
04-26-2006, 07:53 AM
It can be tricky, the first time I did mine, I had French in the DIC display; now that really peed me off.
Second time, it was easy.
04-26-2006, 03:05 PM
